Replacement Rockers
24 replies to this topic
#16 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 27 February 2020 - 10:29 AM
Oops double post! ;D
Edited by gazza82, 27 February 2020 - 10:29 AM.
#17 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 27 February 2020 - 08:05 PM
Aren't standard forged rockers around 1.2/1.3? Assuming you can find a set .. ;D
Minispares do these, recommended for small bore
#18 croc7
croc7
  • 815 posts
Posted 27 February 2020 - 08:39 PM
I read Kieth’s article and wish MS did a 1.3 version. Did look at Kieth’s website - they are costly.
Rocker Arm, Forged, w/ Hardware (12G1221E)from Seven Enterprises in California.  $19 each but includes adjustment screw and locknut.
#19 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 27 February 2020 - 10:52 PM
Isn’t that the same part sold by Mini Spares. Says it’s recommended for small bore engines. What about large bore?
#20 croc7
croc7
  • 815 posts
Posted 28 February 2020 - 07:57 AM
Same ratio used on the 1275 Cooper S.
#21 ACDodd
ACDodd
  • Mini Docs
  • 2,765 posts
Posted 28 February 2020 - 04:31 PM
The 's'reproduction forged rocker gives about the same.liftbas the stock A+ rocker.
I am working on the s ones this year to make them.into '0' tolerance 1.28 or 1.3:1 ratio.
Ac
#22 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 02 March 2020 - 08:50 AM
Ac
So the question is, I am looking at the rockers / rocker assembly to use on, or in place of, my stock Metro 1275 Rocker Assembly in the Metro A+ 1310 that I am rebuilding (Using your RS Cam, Lightened Flywheel, Stage One Kit and Stage 2 Head).
Would these Forged Rockers be ok, seems a shame no one does a complete 1.3:1 assembly (for the same price as the MiniSpares 1.5:1 High Lift.
#23 ACDodd
ACDodd
  • Mini Docs
  • 2,765 posts
Posted 02 March 2020 - 01:05 PM
These rockers give no more lift than the Stock sintered A+ ones, and just the same variability. The pads are also not hardened either. One of my next projexts is to re-work these to give 1.3:1 ratio.
I have a solution for you, my 1.28:1 a+ rocker set is what you need.
Ac
#24 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 02 March 2020 - 09:26 PM
Ac
Sent you an email.
#25 OzOAP
OzOAP
  • 387 posts
Posted 05 March 2020 - 01:07 PM
Buy 10 instead of 8 as occasionally a crap one turns up. I also change tappet adjusting screws after having a failure.
