Engine Rebore ,crank Regrind
17 replies to this topic
#1 nollyd
nollyd
  • 663 posts
Posted 04 March 2020 - 11:09 AM
Hi all,im in the process of stripping a 1098 a+ engine,have decided the crank needs regrind,and maybe have bores done in block,how will this affect power etc,do i need to replace pistons.how much oversize should i go in bores.and are there any other reccomendations to do while engine is stripped.putting new oil pump etc in.
#2 nollyd
nollyd
  • 663 posts
Posted 04 March 2020 - 11:11 AM
Also does anyone know to a macine shop in walsall area and approx cost of rebore and regrinding.
#3 Steve220
Steve220
  • 5,059 posts
  • Local Club: BMC
Posted 04 March 2020 - 11:56 AM
Re-bore = new pistons and rings. Go to the next size up, which is usually +20.
Crank grind = new bearings.
#4 Steve220
Steve220
  • 5,059 posts
  • Local Club: BMC
Posted 04 March 2020 - 11:57 AM
Replace oil pump, water pump and all gaskets/seals as a minimum. You'll have to pull the gearbox off so worth checking that over, primary gear wear etc
#5 Steve220
Steve220
  • 5,059 posts
  • Local Club: BMC
Posted 04 March 2020 - 11:58 AM
Southam Mini and metro centre are the other side of brum. They did my engine.
#6 nollyd
nollyd
  • 663 posts
Posted 04 March 2020 - 12:12 PM
Cheers Steve220,its all stripped,just cleaning up at the mo,yes new bearings etc will go in.
#7 Steve220
Steve220
  • 5,059 posts
  • Local Club: BMC
Posted 04 March 2020 - 02:59 PM
I wouldn't bother cleaning it up. Any engine builder worth their money will have to acid dip it anyway.
#8 blacktulip
blacktulip
  • 6,224 posts
Posted 04 March 2020 - 04:09 PM
I always say go to the next size so you can maximise the life of the block.
#9 Spider
  • 15,017 posts
Posted 04 March 2020 - 05:11 PM
In checking on Machine Shops, ask what type of machine they have for doing the Crank Grinds. If it's a Prince, run like hell.
These are a weird grinder that follows exactly the journal that's in the crank, only, it will make it round again. So, if there's any error in the journal's location, which 90% of the time there is, it will leave that error in the crank. These appear somewhat popular in the UK as they are a cheap machine, take up little floor space and are fast to set up.
Look for a shop that has an off-set type Crank Grinder.
#10 nollyd
nollyd
  • 663 posts
Posted 04 March 2020 - 06:00 PM
All great advice,thanks all.the bores on the block are not scored or damaged,they have a very slight lip at the top of the bore,whats your thoughts on that please.
#11 Steve220
Steve220
  • 5,059 posts
  • Local Club: BMC
Posted 04 March 2020 - 07:51 PM
Rebore +20.
#12 nollyd
nollyd
  • 663 posts
Posted 05 March 2020 - 06:46 AM
Ok,so +20 thou,crank regrind new bearings etc,is it new pistons and rings or just rings?. Also when checking the gear box over i need to check gears,teeth,bearings,shafts etc,now the baulk rings,when the ring is engaged what gap should i be looking for.
#13 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 05 March 2020 - 07:55 AM
Your going to need bigger pistons
#14 G'Racy
G'Racy
  • 174 posts
Posted 05 March 2020 - 08:40 AM
You could try Bromsgrove Engine Services, short trip down the M5 from where you are.
#15 timmy850
timmy850
  • 3,366 posts
  • Local Club: MITG
Posted 05 March 2020 - 09:05 AM
And you will need to get them to check the bore first before you order anything. Maybe the block is already oversize and you need to go to +040 from stock, or possibly the block won't clean up at the next bore.
Same goes for the crank bearings/journals
