Accommodating The Distributor. 123 Ignition
21 replies to this topic
#16 PACINO
PACINO
  • 775 posts
Posted 08 March 2020 - 04:37 PM
Cheers man!! I've got a rocker stud.
Edited by PACINO, 08 March 2020 - 06:55 PM.
#17 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 08 March 2020 - 05:32 PM
Red!
#18 PACINO
PACINO
  • 775 posts
Posted 08 March 2020 - 07:57 PM
Thinking about this, if I extract the distributor drive spindle and I turn it 180 degrees, the rotor'll not be pointing to the direction Piston 1 when you get the TDC, and I'need to rotate all the spark wires.
#19 GraemeC
GraemeC
  • 7,446 posts
Posted 08 March 2020 - 08:16 PM
No, because you will also rotate the distributor, complete with cap, through 180 degrees.
#20 PACINO
PACINO
  • 775 posts
Posted 08 March 2020 - 09:01 PM
Hi! I understand that if you rotate those 180 degrees, when the spark wires now go up, then they will come down. But I do not care about that. What worries me is that if the Distributor turns 180, it will be more difficult for me to adjust the distributor timing at its right point, because if the rotor now points to Piston one when it is in TDC, after this operation, the rotor will point to the opposite point.
Are you agree?
Edited by PACINO, 08 March 2020 - 09:03 PM.
#21 mk1leg
mk1leg
  • 9,343 posts
Posted 09 March 2020 - 05:42 PM
use a longer Vac hose
#22 PACINO
PACINO
  • 775 posts
Posted 09 March 2020 - 10:50 PM
Yes, it is a possibility. I am not convinced to remove and turn the distributor drive spindle. Thank you friend!
