Im about to wire one into my car, i no i need to put the earth somewhere on the body and the postive on the fuse box but can someone please tell me which fuse to plug it into, i want it to come on when i turn the ignition on...
fuse_box.JPG 13.11K
20 downloads
Cheers...
cigarette lighter
mini_dave
, Oct 25 2006 09:20 PM
3 replies to this topic
Posted 25 October 2006 - 09:20 PM
Posted 25 October 2006 - 10:08 PM
Fuse between 1&2 -- stoplights, reversing lights, indicator flasher unit, heated rear window. Only working when key switch is on position II.
Fuse between 3&4 -- horn, hazard indicators, and brake failure light. These work all the time.
Fuse between 5&6 -- heater/wipers - these work on position I or II
Fuse between 7&8 -- side and taillights work all the time.
So the one you want is no.2 with the green wire.
Posted 25 October 2006 - 10:27 PM
Cheers for that mate...
Posted 26 October 2006 - 10:52 AM
When I put one in I just poked them with an electrical testing screwdriver till it lit up with the key turned (Y)
My fusebox only has two fuses in it though.
