Do you use any type of sealant when fitting a windscreen like modern cars.
Windscreen fitting
Maxmini
, Oct 25 2006 09:58 PM
5 replies to this topic
Posted 25 October 2006 - 09:58 PM
Posted 25 October 2006 - 10:04 PM
no, all you need is the windscreen rubber and the filler strip to go in it.
Posted 25 October 2006 - 10:06 PM
No, just the black outer rubber, and the beading strip in the middle
id recomend buying the inser tool for putting the bead back in, makes life so much easier, as does a smear of washing up liquid.
Posted 25 October 2006 - 10:16 PM
you can use windscreen sealerDo you use any type of sealant when fitting a windscreen like modern cars.
i use it when fitting mini glass just to make sure the 1 i use is arbomast autograde windscreen sealer by adshead ratcliffe you can get it from windscreen fitters if they will sell you a tube, i got mine with a new set of glass its about £8 a tube
the number for the company that make it is 01773 826661 there in
derby rd
belper
derbyshire
de 56 1wj
hope this helps
Posted 26 October 2006 - 12:13 PM
personally i wouldnt use washing up liquid, its got salt in it and we all no what salt does to rubbers and metal!
Posted 26 October 2006 - 04:37 PM
Took both my screens out a couple of days ago. There was some old dry sealing paste left on the bodywork at the top and half way down the sides, none anywhere else.
Is it true that the rear windscreen joint comes oversized and needs to be cut ????
What's the trick for cutting it square ?
