Yeterday I replaced my 5.5x12 minilites for some 6x10 revos, when I took the rear wheels off there were some fat spacers behind them, must have been a good inch, or the biggest you can get anyway. I had to fit the revos and still use the spacers because the studs have been changed to account for the spacers. This means my rear tyre tread is showing from my arches by about 15mm.
However, my front wheels look a little over arched.
At the moment I'm using the narrower group two arches.
The tread poking out is an mot faliure, so...
Do I;
1. Buy smaller spacers for the back, replace the rear studs to suit
2. Buy the same size spacers for the front wheels as what Iv got on the back at the moment and studs, then buy the wider group 2s seeing as mine are a little tatty anyway.
Hmmmn.
Next issue..
As your looking at the rear of the mini, the right wheel has a fair amount of possitive camber and the left wheel has a fair amount of negative camber.
Why??
Also my car sits slightly lower on the right hand side, my mechanic thinks this is because the knuckle joint is worn?
Sam
Any help much aprechiated!
Edited by Sammy D, 26 October 2006 - 08:01 AM.
