Pedal Box Bore Sizing And Braking
brakes
Best Answer nicklouse , 01 April 2020 - 09:59 PM
Nope.
5/8 front
7/8 or 1” rear
depends on the rear weight.
clutch same as standard.
Go to the full post
9 replies to this topic
#1 BudgieCake
BudgieCake
  • 77 posts
  • Local Club: Midweekminis
Posted 01 April 2020 - 09:32 PM
Hello Gents, I have a predicament. Im switch over to a wilwood pedal box and the bore sizes I can choose from are 5/8, 3/4 & 7/10.
I am running the later rear cylinders which is 3/4 I believe? and up front I will be fitting the KAD 4 pot brakes (7.75s
In my basket I have bought 3 master cylinders. One for the clutch, rear brakes and front brakes. Sizes are that follows
  • Front brakes - 3/4 bore
  • Rear brakes - 3/4 bore
  • Clutch -  7/10 bore
Does all this look up to scratch before I do some wight saving wallet business?
Cheers, and dont worry what im up to lads
#2 nicklouse
  • 18,660 posts
Posted 01 April 2020 - 09:59 PM   Best Answer
Nope.
5/8 front
7/8 or 1” rear
#3 BudgieCake
BudgieCake
  • 77 posts
Posted 01 April 2020 - 10:14 PM
Nope.
5/8 front
7/8 or 1” rear
Mr Louse, my hero, you are
#4 nicklouse
  • 18,660 posts
Posted 01 April 2020 - 11:02 PM
Just taken from the KAD info that comes with their brakes.
if you want I can give you the sizes I have on mine. Later on after I have slept.
#5 Spider
  • 15,047 posts
Posted 01 April 2020 - 11:43 PM
What's the Pedal Ratio on these ?
Might want to take that and total Pedal Travel in to account as well.
#6 BudgieCake
BudgieCake
  • 77 posts
Posted 02 April 2020 - 06:56 AM
I'd appreciate that Nick!
MokeSpider, gosh don't throw another variable into the mix! It's the adjustable 6.25 box. I would be afraid of drilling the pedal if needs be to change about the pivot and throw of it. Glad you pointed it out!
#7 Spider
  • 15,047 posts
Posted 02 April 2020 - 09:52 AM
Hehehehe,,,,,,
No need to change the Pedal Ratio, but it really needs to be taken in to account when working out M/C Bore sizes.
#8 BudgieCake
BudgieCake
  • 77 posts
Posted 02 April 2020 - 09:59 AM
Hehehehe,,,,,,
Ill have to have a little poke about on google
#9 nicklouse
  • 18,660 posts
Posted 02 April 2020 - 11:23 AM
Ok I got the KAD bias box with the AP RACING MCs one is 0.875 and the other is 0.625
#10 BudgieCake
BudgieCake
  • 77 posts
Posted 02 April 2020 - 11:32 AM
Perfect, right Ill get them ordered! Appreciate that lads. I read somewhere that manual braking ratio is usually 6:1 where as servo assisted is 4:1, how true that is im not sure but I think I will just send it, when the car goes arse over tit Ill let you know that the pivot point is wrong! Haha,
Cheers, Tom
Also tagged with one or more of these keywords: brakes
