Has Anyone Replaced Bullet Connectors Behind Grill?
16 replies to this topic
#1 MikeRotherham
MikeRotherham
  • 992 posts
Posted 05 April 2020 - 05:08 PM
Just wondered if anyone had replaced the headlamp bullet connectors behind the grill for something more modern.
About the best thing that you can say about the present bullet connectors is that they are compact.
So has anyone replaced them and if so what with?
Edited by MikeRotherham, 05 April 2020 - 05:08 PM.
#2 Chris1275gt
Chris1275gt
  • 969 posts
Posted 05 April 2020 - 05:31 PM
I've kept mine but sealed them with small diameter shrink wrap to keep the elements out,if you need to take them apart cut it off with a Stanley knife and put a new bit of wrap when you're done.
#3 area51
area51
  • 42 posts
Posted 05 April 2020 - 05:55 PM
I have used the tyco econoseal connector, you can get them from online automotive suppliers and RS, I do have a crimp tool for the terminal to get a better crimp.
They are sealed aswell at the wire entry
#4 sonscar
sonscar
  • 3,076 posts
Posted 05 April 2020 - 07:08 PM
At the risk of being derided I ran new looms from each side under the wings and connected them under the dash using relays for the lights.I will probably be soundly cursed by the next owner.Steve
#5 Stu1961
Stu1961
  • 637 posts
  • Local Club: Still Looking
Posted 05 April 2020 - 07:22 PM
Made a new harness for the front lights and eliminated the connectors altogether, now I only have connections at each headlight and the relays.
Edited by Stu1961, 06 April 2020 - 08:13 PM.
#6 wassupcrew
wassupcrew
  • 502 posts
Posted 05 April 2020 - 07:29 PM
https://www.ebay.co....4b1ada49fba891d
I think these are the connectors area51 is talking about. I use these aswell, for all my add-ons as they are waterproof and much easier to take apart than bullet connectors.
Make sure you get the tool to crimp the pins properly as it does a really good job of it
#7 area51
area51
  • 42 posts
Posted 05 April 2020 - 10:01 PM
#8 area51
area51
  • 42 posts
Posted 05 April 2020 - 10:03 PM
They are “super seal “ a bit dearer than econoseals but they are very good.
Econoseals where used from the mid 90s on minis and defenders to replace the crap mould and bullet terms
#9 area51
area51
  • 42 posts
Posted 05 April 2020 - 10:06 PM
https://www.ebay.co....t-/131020386671
#10 MikeRotherham
MikeRotherham
  • 992 posts
Posted 06 April 2020 - 07:26 AM
Thanks for all your input quite a few ideas there to consider
#11 Compdoc
Compdoc
  • 612 posts
Posted 06 April 2020 - 08:42 AM
I agree with Sonscar and Stu1961. I can see nothing wrong in modifying any classic to improve a poorly designed part. Running new wires from the relays to the headlights is by far the best idea. Plus the addition of a couple of fuses wouldn't go amiss.
To help the next owner, I always use the correct wiring colour codes and create a diagram of any wiring changed to add to the cars manual. If you want to make it super neat you can use program such as TinyCad.
https://sourceforge....ojects/tinycad/
It's a bit basic but it is a free download.
#12 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 06 April 2020 - 10:02 AM
The only problem I can see is where the bullets are used to connect three or four wires together .. bullets are great for that but I can't find a modern equivalent .. without splicing multiple wires into one connection which I don't really want to do.
#13 bpirie1000
bpirie1000
  • Area Managers
  • 2,414 posts
  • Local Club: Amoc
Posted 06 April 2020 - 11:04 AM
Solder?
#14 Quinlan minor
Quinlan minor
  • 1,219 posts
  • Local Club: LSMOC
Posted 06 April 2020 - 11:57 AM
Or do the equivalent of this into one side of a multi plug.
#15 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 06 April 2020 - 04:11 PM
Solder?
Not recommended on a car as it makes wiring brittle ..
I was thinking of something like that where it was distributing to different units but a single-post with ring terminals for something like the panel lights where it is one feed and several links from it, of which there are going to be a few ..
This would be a 4-way bullet with one input and three out .. I want one in and about 11 out! I've seen a wiring diagram with a 6-way bullet but don't think they are available now.
Attached File  bullet_4-way.jpg   13.34K   5 downloads
I also want to hide it as much as I can and keep the number of screw fittings to a minimum (loose wires?)  .. planning to have any "spaghetti" inside cabin and behind the dash out of sight so that helps ..
