Where would you put it in the Y piece or in the center branch pipe?
Adding A Lambda Sensor To An Lcb.
Posted 07 April 2020 - 07:14 PM
Posted 07 April 2020 - 07:24 PM
Posted 07 April 2020 - 09:22 PM
I read somewhere that lambda sensor should be 18 inches or so from the exhaust port - I'll link the source if I can find it..
Edit - install details for one of the pro sport far kits
http://prosportgauge...JDMWIDEBAND.pdf
Edited by KTS, 07 April 2020 - 09:31 PM.
Posted 07 April 2020 - 09:43 PM
Posted 07 April 2020 - 09:53 PM
Put mine on the middle pipe just behind where the Y branch joins into it. Felt that was the only place that had enough from to get in pointing slightly downward and got a proper reading for all cylinders.
Posted 08 April 2020 - 12:31 AM
Rover can’t have read that, since they fitted it in the cast manifold.
Posted 08 April 2020 - 08:40 AM
Right can of worms.When I seeked advice on my MGB similarly siamese port I was advised you needed 2 or 3 to see the individual cylinders.I went for one in the centre cylinder of the cast manifold.Steve..
Posted 08 April 2020 - 09:16 AM
that was nearly 20 years ago
i assumed, rightly or wrongly, that if he's looking to add a lambda sensor to the car he might be considering something a little more modern.
there appear to be a number of different types of lambda sensor that could be used (narrow band,wide band, heated/non-heated) and each may have it's own set of requirements, so perhaps the starting point is to identify which type is going to be used before deciding where it should be installed
Posted 08 April 2020 - 09:28 AM
Mine's under the floor, the supplier (14point7) recommend about a metre from the valves.
I suppose you'd have to make an educated guess on whether innies or outies (cylinders) are more critical.
Outers are likely to have lower pressure because of the siamese ports. Inertia is also likely to throw them more liquid fuel from a single carb or injector.
Posted 08 April 2020 - 09:40 AM
I would want it before the y-piece as they are such a pain to seal that I doubt you'd get an accurate reading. For tuning you could add two bungs (one in an outter, one in a inner runner) and then for day-to-day running just use the one that gives the best indication of overall running conditions.
Posted 08 April 2020 - 09:53 AM
Posted 08 April 2020 - 09:56 AM
That is a good point.
Though I'd opt for the leanest reading pair because too rich won't melt your pistons so much. I reckon that'd be the inner two.
Years ago a more observant spanner monkey than me pointed out to me that A's have a habit of coming to a stop at the start of No2's power stroke.
Posted 08 April 2020 - 10:19 AM
i thought the outers typically run leaner ?
below is a forced induction setup, but certainly shows a marked difference
http://www.theminifo...50#entry3605833
Posted 09 April 2020 - 05:54 PM
Mines just after the Y piece to get an average reading of all cylinders. Only really needs to be closer for closed loop control to keep lambda at 1.0 as much as possible for maximum convertor efficiency.
Posted 09 April 2020 - 06:01 PM
Unfortunately mine can’t go there as there is a gear change housing in the way.
Edited by nicklouse, 09 April 2020 - 06:01 PM.
