Adding A Lambda Sensor To An Lcb.
28 replies to this topic
#16 nicklouse
  • 18,999 posts
Posted 27 May 2020 - 07:15 PM
finally sorted the position. it is as close to the valves as possible when being able to sense all cylinders.
after the remote housing rear bracket.
#17 KTS
KTS
  • 2,490 posts
Posted 27 May 2020 - 07:43 PM
out of curiosity Nick; are you installing it for an AFR gauge or some type of management system ?
#18 nicklouse
  • 18,999 posts
Posted 27 May 2020 - 08:00 PM
I may but the reason for it is German motorsport regs.
#19 croc7
croc7
  • 878 posts
Posted 28 May 2020 - 01:41 AM
Where would you put it in the Y piece or in the center branch pipe?
Instructions for mine says to install 18" downstream from the collector (Y piece in our case with the LCB).
#20 nicklouse
  • 18,999 posts
Posted 28 May 2020 - 10:43 AM
And as already said no room.
#21 nicklouse
  • 18,999 posts
Posted 01 June 2020 - 06:15 PM
had to mock up the exhaust for other things so some pictures in place
#22 postve
postve
  • 588 posts
Posted 01 August 2020 - 01:52 AM
Hey guys, so anyone have a suggestion for a wide band lambda sensor?
#23 PoolGuy
PoolGuy
  • 975 posts
Posted 01 August 2020 - 06:40 AM
I’ve had the PLX wideband fitted for a couple of months. Very happy with it, and I can add more sensors to it if I need to.
ETA, Timmy850 has an Innovate afr fitted, there’s info about it in his build thread.
Hmm, strange edit function here. Why didn’t my original post show when I tried to edit?
Edited by PoolGuy, 01 August 2020 - 06:56 AM.
#24 postve
postve
  • 588 posts
Posted 01 August 2020 - 09:20 AM
Thx Pool and I hear it truly helps in extracting the last bit of power/torque from my engine. We have no rolling roads over where I am .
#25 PoolGuy
PoolGuy
  • 975 posts
Posted 01 August 2020 - 11:38 AM
I’ve certainly found it interesting while playing with SU springs and damper oil.
#26 DamoMini
DamoMini
  • 40 posts
Posted 01 August 2020 - 02:57 PM
I have an AEM 30-0300 and am happy with it. It has an analog output so I can log the data. It’s been both informative and fun monitoring the effect of tweaking the carb and also it protects me from tuning way too lean.
Edited by DamoMini, 01 August 2020 - 02:57 PM.
#27 postve
postve
  • 588 posts
Posted 01 August 2020 - 03:12 PM
I have been relying heavily on my gunson and some say not good enough as all I want now is the last few BHP out of the engine. Car runs and drives great but as usual can be deceiving
#28 MiNiKiN
MiNiKiN
  • 217 posts
Posted 06 December 2022 - 11:37 AM
Nick, I notice you seem to have fitted a Maniflow reverse cone system. Have you also fitted the newfangled LCB Stage 2 with larger centre pipe? If so, how did you get on with its routing past the remote housing and hardy spicers (assuming you have fitted all these)
Edited by MiNiKiN, 06 December 2022 - 11:38 AM.
#29 nicklouse
  • 18,999 posts
Posted 06 December 2022 - 02:10 PM
See my build thread
here it is in its natural state https://www.theminif...date-it/page-51
 After some grinder work https://www.theminif...date-it/page-53
