I've been asked to source a replacement 5AS module (clips onto top of brake servo) on an SPI mini.
The owner has replaced the alternator after the old unit failed. Once replaced the car started and run well, then a sudden burning smell and smoke from the 5AS unit.
I was given the unit with the case unfastened. Here is my initial issue....
The red wire runs from lower left terminal (viewed looking at the connector end) to a diode or resistor next to the Front Left relay (again viewed from the connector end). This has been repaired previously and the soldering looks professional.
Apologies for the poor quality image, couldn't get my phone to focus.
The small brown diode (located between the small connector block and left hand relays) has a small area of melting but no blackening, presumably from the previous repair.
Is there any way I can test this unit with a power probe or multimeter?
Can it be repaired, or would it be easier to replace?
(ADMIN, I'd posted here to get a more general opinion, please move of needed)
Thanks and kind regards
Cal
Edited by cal844, 21 April 2020 - 06:17 PM.
