5As Module Smoke And Burning Smell After Alternator Replacement
16 replies to this topic
#16 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 22 April 2020 - 05:42 PM
I would still encourage you to have a go with the Multimeter, even if it is just getting replaced will give you a bit of experience.
Also keep hold of the board for spare relays, handy for repairs should a similar problem occur.
#17 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 22 April 2020 - 05:51 PM
I have a spare SPI one if it would help?
I've tried a multimeter on the unit this morning, the Fuel Pump Relay was stuck open, I then fitted it to the car to energize the circuits, the FP Relay wouldnt close unless gently tapped with a screwdriver handle, then worked until I cut power and let the relays de-energise.
I have passed the case on to our auto electrician to repair, I also have a new unit on order, just incase we have issues, I will clean all the terminals and earth to body connections.
Thanks all for the help and test procedures, I've learnt alot
Edited by cal844, 22 April 2020 - 05:52 PM.
