Hi all,
I have a 1380 engine with a swiftune SW5 cam, I use12 inch wheels on the mini, I've recently had to do a rebuilt of the gearbox which turned out to be the layshaft bearing collapses, I got to it time before any damage to lay-gear or the casting.
The final drive I currently use is a crown wheel of 59 teeth with a 19 tooth pinion gear, ratio 3.1, it has good acceleration in lower gears but I'm not happy with the top speed it achieves in fourth gear, hard to reach 70 mph.
I have another crown and pinion gear pair which is 58 teeth with a 20 tooth pinion gear, would this alter what I currently experience in acceleration and top speed if so in what way, or should I use another ratio setup to provide a better balance between acceleration and top cruising speed, I am aware what ever I use will be compromise, I would appreciate some advice advice.
Steve
