If it's all been balanced I'd be tempted to keep the diaphragm if there's nothing wrong with it and just replacethe centre plate. My orange diaphragm's 30 years old now and still going strong.
Very difficult to find that centre thrust plate. Nobody seems to stock them. There’s a couple in the USA but they work out dearer than a new complete diaphragm.
I think he means the clutch driven plate - not the diaphragm thrust plate.
Yeah I mean replace the clutch driven plate only.
The thrust plates don't normally wear unless the clutch is incorrectly adjusted and the release bearing has been in constant contact with the thrust plate.(the thrust plate used to be available separately)
I've just replaced my pre verto release bearing and fitted the heavy duty bearing from mini spares - this type has a much greater surface area in contact with the thrust plate. I'm sure this used to be the standard release bearing that was used years ago.
Edited by imack, 27 April 2020 - 09:01 AM.
