That's the one I've got. The smooth ground side goes towards the thrust plate, writing towards wok.I bought a KOR comp thrust bearing. But I’m not 100% sure which was round it goes. Does the side without writing face the clutch? All previous bearings have been the same both sides so never questioned it. I assume the flatter side goes against the thrust plate?Yeah I mean replace the clutch driven plate only.I think he means the clutch driven plate - not the diaphragm thrust plate.
Very difficult to find that centre thrust plate. Nobody seems to stock them. There’s a couple in the USA but they work out dearer than a new complete diaphragm.If it's all been balanced I'd be tempted to keep the diaphragm if there's nothing wrong with it and just replacethe centre plate. My orange diaphragm's 30 years old now and still going strong.
The thrust plates don't normally wear unless the clutch is incorrectly adjusted and the release bearing has been in constant contact with the thrust plate.(the thrust plate used to be available separately)
I've just replaced my pre verto release bearing and fitted the heavy duty bearing from mini spares - this type has a much greater surface area in contact with the thrust plate. I'm sure this used to be the standard release bearing that was used years ago.
Edited by imack, 27 April 2020 - 09:30 AM.
