Rear Heelboard Issues
Posted 03 May 2020 - 10:07 AM
As the subframes off the car I thought I’d bolt the panel to the subframe and then use this to line up the heelboard. How ever when I’ve come to do this, the distance between hole centres in the trunnions are about half a hole out (closer) than the heelboard panel.
Has anyone come across this before? What’s the best way to rectify this? Can I space the trunnions bolts out slightly or am I best to cut the panel down the middle and shorten it equally each way?
Thanks!
Posted 03 May 2020 - 10:23 AM
Use spacers to space the grunion carriers to the required distance.
Posted 03 May 2020 - 10:45 AM
Heritage or Magnum Heelboard???
Posted 03 May 2020 - 10:52 AM
Posted 03 May 2020 - 10:54 AM
Just put them between the Shoulder of the bolt and the subframe?Use spacers to space the grunion carriers to the required distance.
Posted 03 May 2020 - 11:14 AM
Have you fitted new rubber bushes to the trunnion or are they the old ones??
Posted 03 May 2020 - 11:16 AM
and if later ones fitted them the correct way around.
Posted 03 May 2020 - 11:24 AM
I did opt for poly bushes (that was what was already on there from the last owner and I know the rubber on the mini scene can be very hit and miss)
Edited by Mcbudge, 03 May 2020 - 11:29 AM.
Posted 03 May 2020 - 11:30 AM
Yeah I’ve put new bushes in and tried them both ways. The correct way round for them actually brings the holes even closer and are nearly a full hole out!
just checking
rear bush.JPG 29.13K 7 downloads
Posted 03 May 2020 - 11:50 AM
Posted 03 May 2020 - 11:52 AM
Posted 03 May 2020 - 11:56 AM
Just going back a step, is the original heelboard still on the car?? Have you carefully measure the spacing of the trunnion bolt holes on it??
Posted 03 May 2020 - 12:01 PM
Edited by Mcbudge, 03 May 2020 - 12:07 PM.
Posted 03 May 2020 - 12:13 PM
It is at time like this where I wish I had done a study on the differences between how the rubber and the polly bushes pulled up.
i am sure the polly ones will be compressing the inner part more as it does not spread as well at the other end.
