Rear Heelboard Issues
#31
Posted 04 May 2020 - 09:49 PM
#32
Posted 05 May 2020 - 11:58 AM
#33
Posted 05 May 2020 - 01:33 PM
so subframe looks to be OK. that leaves the trunnions themselves or the bushes you're using
trunnions - you want c.92mm to the shoulder below the threaded section. the shoulder butts up to the inner mounting presumably to stop the bushes being overcompressed
if the trunnions are ok, then it only leaves the bushes as these fix the relative position of the mounting brackets to the subframe
edit : just noticed you appear to have the bushes fitted the wrong way round. may be part of the issue
Edited by KTS, 05 May 2020 - 01:36 PM.
#34
Posted 05 May 2020 - 04:17 PM
I originally had them fitted the way in your picture, but this still didn’t help. Made it fractionally better but not quite there!so subframe looks to be OK. that leaves the trunnions themselves or the bushes you're using
I’ve fitted them this way as nicklouse had this picture of what looks like the workshop manual (posted on page 1 of this thread) that shows the bushes orientation. I’ve attached the picture here.
Measured the trunnions at 92 and 91.5 so they’re okay!
Edited by Mcbudge, 05 May 2020 - 04:22 PM.
#35
Posted 05 May 2020 - 04:23 PM
#36
Posted 05 May 2020 - 05:04 PM
..in that case, although it's not a '96 car, but i am using the single piece bushes, i'd better put mine on the right way round
#37
Posted 05 May 2020 - 05:33 PM
AKM7169 Rover service manual 92-96..in that case, although it's not a '96 car, but i am using the single piece bushes, i'd better put mine on the right way round
#38
Posted 15 May 2020 - 07:50 PM
#39
Posted 16 May 2020 - 11:11 PM
I’m afraid not! I’ve set my trunnions at the 50.5” gap and then lined the new panel up like this. I will look in further detail when I come to refit the subframe!Any updates on this as I’ve just come across the same issue. But on a heritage whole floor and the old bushes still in the subframe?
#40
Posted 16 May 2020 - 11:34 PM
If your heel board measures 50.5 inches from centre to centre on the trunnion mounting holes the panel’s fine fit it to the car.
If you’re struggling to fit the subframe then loosen the trunnion pins so that you can wriggle the trunnions around and get them lined up.
If you’re really struggling then bolt the trunnions with the rubber bushes fitted then lift the subframe up and slide the pins in.
#41
Posted 17 May 2020 - 07:32 AM
#42
Posted 17 May 2020 - 11:18 AM
