Brakes Not Braking Properly?
25 replies to this topic
#1 Toffe98
Toffe98
  • 30 posts
  • Local Club: Mini Club Flying Finns
Posted 04 May 2020 - 12:33 PM
Hi all! Just got my mini to the point of test driving it after a full restoration, but the brakes seem to not work properly. The whole braking system is new and running 8.4" discs at the front and drums with 1/2" cylinders in the rear, aswell as a GMC227 master (the yellow tagged one). So the problem is that it does indeed brake a little, but I'm unable to get any wheels to lock up and the brakes just seem kinda "sloppy". The pedal feel however is decent I think (never driven another Mini with a properly working braking system so not 100% sure) and I've bled the brakes multiple times and got just clear fluid with no bubbles coming out in all corners. Any idea what might cause the issue or how I should try to fix it?
Thanks in advance!
- Toffe  :D
#2 unburntfuelinthemorning
  • 1,987 posts
Posted 04 May 2020 - 12:36 PM
Have you adjusted the rear brakes for minimal shoe to drum clearance?
#3 Toffe98
Toffe98
  • 30 posts
Posted 04 May 2020 - 01:31 PM
Yep, rear brakes are adjusted properly aswell
#4 Chris1275gt
Chris1275gt
  • 959 posts
Posted 04 May 2020 - 01:45 PM
What mini is it?
#5 Toffe98
Toffe98
  • 30 posts
Posted 04 May 2020 - 01:55 PM
Yeah sorry forgot to mention that, it's a 1981 Mini 1000 with a 1275 engine
#6 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 04 May 2020 - 03:48 PM
Are the brake shoes on the correct way?
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,057 posts
  • Name: Neil
Posted 04 May 2020 - 03:51 PM
Are the calipers new and on the correct side with the brake nipple at the top.
#8 Avtovaz
Avtovaz
  • 1,262 posts
Posted 04 May 2020 - 04:27 PM
if its all new, does it not just need bedding in? Have you done many miles with it?
#9 Toffe98
Toffe98
  • 30 posts
Posted 04 May 2020 - 06:27 PM
Yeah, good suggestions but checked both multiple times already and they're on as they should, thanks though!  :lol:
That's entirely possible that it just needs bedding in, haven't done more than maybe 10km (6 miles) yet. How much would it need to bed in properly?
Cheers!  :proud:
#10 Toffe98
Toffe98
  • 30 posts
Posted 04 May 2020 - 06:29 PM
And yes, the calipers are brand new  :D
#11 Homersimpson
Homersimpson
  • 831 posts
Posted 04 May 2020 - 06:36 PM
Are you comparing the brakes to a modern car? Even discs on a mini sent as effective as modern brakes.
Do you have a servo?
#12 Quinlan minor
Quinlan minor
  • 1,201 posts
  • Local Club: LSMOC
Posted 04 May 2020 - 06:46 PM
Probably want a good thirty to fifty miles to settle them in. Pads usually recommend a hundred plus miles, avoiding heavy braking.
This from EBC:
  • "Use brakes with minimal pressure for first 100 miles from urban speeds of 30-50 mph only.
  • Drive a further 250 miles using slightly increased brake pressure and load UNLESS in an emergency in which case apply brake as hard as required.
  • Look for a full width contact across the pad depth( rotor braking band) from the outer edge of the disc to the inner and if not achieved allow a further 100-200 miles steady driving. You will see a blue-ish band evidencing contact across the rotor face. Until this band goes from the outer to the inner edges of the brake disc/rotor the pads have NOT yet fully seated. When installing new rotors, reduced width banding is quite possible due to various tolerances and slight misalignments in the vehicle chassis and is NOT a warranty defect or a reason to remove and inspect brakes. Many European cars have SINGLE PISTON CALIPERS and these tend to “Flair” open and cause the contact band described above only to be seen at the outer edge of the disc/rotor and work its way inwards taking up to 1000 miles to do so.
  • After full width contact band is attained make a further 10 stops from 60 mph to 10 mph in succession with a deliberate attempt to get the brakes hot. Some smells may occur even slight smoke during this final heat up stage of the pads in early life. Then coast the vehicle for a mile to allow discs to cool. Do not pull up and park vehicle with brake excessively hot. You must try to get the discs down to below 60-80 degrees C temperature before parking the vehicle.
  • When parked let brakes cool to a final cool-to-touch point. Before touching discs splash a few tiny drops of water onto the disc to asses its temperature to avoid burning fingers. If the water spots cause a “hiss” you have parked up too soon and should go out and drive slowly allowing the brakes to cool further.
NEW DISCS TAKE LONGER TO BED IN
  • Fully bedding new pads to decent condition worn discs/rotors may take only 200-300 miles but when new discs are fitted at the same time bed in times to achieve outer to inner edge contact ( full width blue-grey contact band as mentioned under point 4 above ) can be as long as 800-1000 miles due to extra components needed to be aligned to the vehicle. To Short cut this you can ( and EBC recommend should) have EVEN NEW DISCS Pro Cut Lathe aligned to your vehicle. This process removes only microns of new disc material and shortens bed in time by 75% of the time it COULD take giving you better brakes faster and avoiding hot spotting and pad glazing."
#13 unburntfuelinthemorning
  • 1,987 posts
Posted 04 May 2020 - 06:57 PM
This from EBC:
Blimey.  Think I'll use a different make then.
#14 Quinlan minor
Quinlan minor
  • 1,201 posts
  • Local Club: LSMOC
Posted 04 May 2020 - 07:12 PM
Here's recommendations from a variety:
https://www.tirerack...e.jsp?techid=85
#15 Toffe98
Toffe98
  • 30 posts
Posted 05 May 2020 - 05:59 AM
This from EBC:
Allrighty then, I'll have a look into getting them lathe aligned if that's available anywhere near where I live, otherwise it's apparently just a matter of driving it to settle them in :D
Nope, no servo. Seemed like too big of a hassle ti get one for a LHD Mini without going with single line brakes, and apparently they're not really needed anyway on a Mini :)
Thanks everyone for the replies! Guess I'm off to driving it some more :D
