Hi all! Just got my mini to the point of test driving it after a full restoration, but the brakes seem to not work properly. The whole braking system is new and running 8.4" discs at the front and drums with 1/2" cylinders in the rear, aswell as a GMC227 master (the yellow tagged one). So the problem is that it does indeed brake a little, but I'm unable to get any wheels to lock up and the brakes just seem kinda "sloppy". The pedal feel however is decent I think (never driven another Mini with a properly working braking system so not 100% sure) and I've bled the brakes multiple times and got just clear fluid with no bubbles coming out in all corners. Any idea what might cause the issue or how I should try to fix it?
Thanks in advance!
- Toffe
Hi
I've noticed on Minispares flow chart for braking systems that the GMC 227 master cylinder is only used with the .75 rear cylinders GWC1102 not the .5 rear cylinders.
