How To Remove 1985 Mini Mayfair Engine
16 replies to this topic
#1 Landyboy007
Landyboy007
  • 29 posts
Posted 08 May 2020 - 07:28 AM
Hi, I am new to this forum so would appreciate as many replies as possible.
I have recently bought myself a classic mini Mayfair to do during lockdown as there is no A levels taking place anymore. I am looking to completely strip everything down, including the engine.
There are many threads on how to remove the engine but if possible, an updated and detailed method would be great!
#2 mab01uk
mab01uk
  • 12,575 posts
Posted 08 May 2020 - 08:47 AM
One of many videos on Youtube:-
Removing An A Series Engine Following The Haynes Manual
Edited by mab01uk, 08 May 2020 - 08:48 AM.
#3 mab01uk
mab01uk
  • 12,575 posts
Posted 08 May 2020 - 08:50 AM
No longer available on DVD but can be seen below on YouTube.
Over 4 hours video with Bill Sollis:-
#4 Landyboy007
Landyboy007
  • 29 posts
Posted 08 May 2020 - 10:16 AM
Hi thanks so much, I’ve already viewed your video multiple times and was really helpful. Does the second video also apply to a 1000cc engine? Are the concepts pretty much the same?
#5 malynch27
malynch27
  • 114 posts
Posted 08 May 2020 - 11:15 AM
As long as you undo/disconnect everything that joins the engine to the car/subframe, the engine can be lifted out fairly easily.  Don't forget the little 2" fuel hose at the bulk head......I did.
Good luck.
#6 Chris1275gt
Chris1275gt
  • 969 posts
Posted 08 May 2020 - 11:30 AM
Buy a Haynes manual it will give you a step by step guide.
#7 Landyboy007
Landyboy007
  • 29 posts
Posted 08 May 2020 - 01:30 PM
Thank you, all useful! I will be tackling this next week.
#8 sonscar
sonscar
  • 3,062 posts
Posted 08 May 2020 - 02:02 PM
Beware the speedo cable.Steve..
#9 mab01uk
mab01uk
  • 12,575 posts
Posted 08 May 2020 - 06:07 PM
Yes main concepts are the same on 1000 & 1275cc A-Series engines, the detail differences you can pick up as you progress..
Edited by mab01uk, 08 May 2020 - 06:07 PM.
#10 MiniMadRacer
MiniMadRacer
  • 893 posts
Posted 08 May 2020 - 06:11 PM
From personal experience...
1. remove the radiator first give more wriggle room
2. I also remove the alternator to get more leverage when trying to get down the back of the engine
3.I undo the carb but leave the cable attached and tuck it out of the way
#11 Landyboy007
Landyboy007
  • 29 posts
Posted 08 May 2020 - 10:06 PM
Ok thanks everyone, all useful! I have also ordered the Haynes manual so combined with this I should have a good go at it! I will let you know how I get on! Thanks again
#12 unburntfuelinthemorning
  • 1,991 posts
Posted 09 May 2020 - 06:16 AM
Playing with an A series is the best A level.
#13 Bobbins
Bobbins
  • 1,525 posts
Posted 09 May 2020 - 07:22 AM
Early summer 1982 and I’m sat in an A-level General Studies exam ... “write about a book you have recently read” was one of the questions .... yes you know where this is going .... I wrote a whole essay about the Haynes Mini Manual 1959 - 1978 ... and I passed the exam!!! I read the manual so many times cover to cover it was likely my best shot at getting a result :)
#14 Pete - W.Sussex
Pete - W.Sussex
  • Just Joined
  • 91 posts
Posted 09 May 2020 - 08:10 AM
Was the final paragraph very short......refitting is the reverse...?
#15 Bobbins
Bobbins
  • 1,525 posts
Posted 09 May 2020 - 08:51 AM
Isn't it always ?
