Yes, the inner flange nut that controls the throw needs set to 6.5mm between that and the wok contact face.Cal, is that 6.5mm only for the Verto ? I set my pre-Verto with a 1/8" Drill Bit...
The inner of the two throw out nuts should have a gap of 6.5mmIt’s a verto one so not sure what adjustments are required? Will check arm for wear .
Edited by cal844, 09 June 2020 - 11:26 AM.
