High Level Brake Light
leepol83
, Jun 07 2020 09:03 AM
4 replies to this topic
Posted 07 June 2020 - 09:03 AM
Hi all I bought a set of rear lights and I’m trying to get the high level brake light wired back in, it looks pretty strait forward, however there is s as black wire with a spade connector attached At the rear light end and I can’t remember whet it goes ?♂️
Has anyone got a picture of the wiring off the back of the rear lights showing where the high level light comes off
Thank you
Thank you
Posted 07 June 2020 - 09:43 AM
Black goes to any convenient ground point on the body. IE: the studs for the rear light attachment, the ground point for the rear window defogger, or any place it can be firmly attached to the body.
Posted 07 June 2020 - 10:21 AM
Got ya the earth is spliced into the light loom then and then another spade connector off that, just wondered why it needed the spade connector If it’s already spliced I to the light earth ?
Posted 11 June 2020 - 06:31 PM
Right been up playing today with this wiring, how does the high level brake light wire in the actual light itself ?♂️ Didn’t take pictures ?
Posted 12 June 2020 - 08:06 AM
Any pictures would be great
Thank you ?
Thank you ?
