Hard Fuel Line
10 replies to this topic
#1 no66
no66
  • 156 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 07 June 2020 - 04:31 PM
Was changing all my rubber fuel hoses as tha car has sat for a long time.
Luckily I found out that the hard fuel line har pretty much corroded through. Snapped off just as in goes under the rear subframe.
Can is use copper/nikkel brake line? See Minispares sell this in 1/4 inch or 5/16
If so, size?
Have a facet eletric pump at the rear that goes to Filterking filter/ regulator to SU on a 1380.
#2 GT Jimmy
GT Jimmy
  • 1,644 posts
  • Local Club: S.U.N.M.C
Posted 07 June 2020 - 04:50 PM
I used 8mm copper tube on my car
#3 johnR
johnR
  • 2,297 posts
Posted 07 June 2020 - 05:02 PM
I've just used 8mm on mine - might be overkill but it was straightforward to run and certainly allows a healthy flow!
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 07 June 2020 - 05:29 PM
I use 8MM microbore, B&Q do a roll of it cheap as chips if your UK based.
If not try your local hardware shop.
Edited by cal844, 07 June 2020 - 05:30 PM.
#5 Avtovaz
Avtovaz
  • 1,243 posts
Posted 07 June 2020 - 06:52 PM
you can get it pvc coated too, that is what i use on my rally car and will do on the mini.
#6 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 07 June 2020 - 08:20 PM
Norway: known throughout the world for its jagged mountains and stunning fjords.... & if i'm not mistaken a country where Copper brake pipes are not allowed.
Steel or Cunnifer pipes are OK (for Cunnifer fit plenty of brake line clips to reduce flexing).
I think Minispares sell kits made by Automec -& i'm not 100% sure that they are Cunnifer & not just pure Copper.
Personally i would order a set of pipes from Richmond Classics
http://www.theminifo...s/#entry3442162
It might cost you more but they WILL be Cunnifer & manufactured to fit whatever modifications you have made (just let them know exactly what you require) & from what other members have written they will be well made, clearly labelled & ready to be unrolled & fitted to the car without any messing about.
Edited by Itsaminithing, 07 June 2020 - 08:23 PM.
#7 no66
no66
  • 156 posts
Posted 08 June 2020 - 07:34 AM
Thanks for the replies
All the car shops here in Norway sell both copper fuel and brake lines so i dont think it banned. Can also get cobber/nikkel mix.
#8 Itsaminithing
Itsaminithing
  • 852 posts
Posted 08 June 2020 - 09:45 AM
My bad, i was wrong :cry:, i thought i read recently that Norway was dropping the statens vegvesen in favour of the German TUV system.
Found out this morning that because the TUV requires pipes made from copper/nickel/iron (or metal) that all Automec LHD kits are made from Cunnifer
....but i still stand by my statement that to save yourself time, effort, & having to invent new swear words that it would be better to get a kit made up by Richmond Classics to fit your car.
#9 Dusky
Dusky
  • 5,322 posts
Posted 08 June 2020 - 10:28 AM
Only because its allowed in airbrake systems.
#10 no66
no66
  • 156 posts
Posted 09 June 2020 - 11:17 AM
Dusky, what do you mean? Nive car, love the Britax colours.
Itsaminithing, Statens veivesen loves TUV though. You could get a turd MOT'd id it had a TUV sticker :-)
#11 Itsaminithing
Itsaminithing
  • 852 posts
Posted 09 June 2020 - 11:49 AM
Ah, i meant to cut & paste periodisk kjøretøykontroll
Pointless submitting a TUV certified poo for an MOT ....the MPG is terrible on those things!
