Toggle Switches
Posted 14 June 2020 - 07:55 PM
Posted 14 June 2020 - 08:39 PM
Yes I did - its fiddly and takes a while and you need to add separate warning lights as appropriate (lights not visible in the picture as I moved them away from the switches and onto the main part of the dash)
Capture99.JPG 31.79K
11 downloads
Hazards slightly complex as you need to keep the L/R circuits separated otherwise most circuits are pretty simple the switch just breaks the live feed
I would say its simpler with Lucas toggle switches as they can be configured to do various things whereas "standard" toggle switches that I've seen are mainly just off/on so can't handle more complex switching although you'll probably find an off/on/on for the headlights and maybe a momentary (flick) switch for the brake test switch but not many can handle the hazards easily
- like a lot of things depends on your skill/understanding/confidence/ability to learn/willingness to have a go
Also I should caution that electrics is one of those things that can cause a fire so please be careful if you do have a go.
Posted 14 June 2020 - 09:16 PM
Posted 14 June 2020 - 11:51 PM
Posted 15 June 2020 - 07:01 AM
Posted 15 June 2020 - 11:19 AM
As has been said, the hazard switch is the most complex but it's a topic that's been covered here many times. I've posted a method that uses two relays (one to break the indicator circuit, the other to make the hazard circuit) and I think there were a couple of other methods post too.
But yes, it's a subject that's well covered on here.
Edit:
Here's one of the posts I was thinking about: link
Edited by Icey, 15 June 2020 - 11:22 AM.
Posted 15 June 2020 - 11:22 AM
Posted 15 June 2020 - 11:38 AM
I did this on my 89 City to Mk1 Cooper s replica build. It's fairly straightforward - I had to lengthen some wires because I was changing to a centre speedo with the extra toggles below the dash. For the hazards I did away with the standard (2?) relays and bought a generic single relay with hazards built in. Just make sure you label all the wires as you take them off the rocker switches.
Posted 15 June 2020 - 12:12 PM
