Switchback Led Front Indicators?
10 replies to this topic
#1 jemo1
jemo1
    Just On Tickover
  • 9 posts
Posted 16 June 2020 - 12:57 AM
Has anyone used LED switchbacks on the front indicators so they act as parking lamps and turn indicators?  Thanks.
#2 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 16 June 2020 - 01:56 AM
I wired my front indicators with dual filament holders (like the MS part# 27H5545) so I could use US type 1157 LEDs. You could easily use white to amber switchbacks. You just reroute the power from the pilot light. You'll need resistors in the circuit if you don't replace the mechanical flasher module with a electronic one. I used 1157 Morimoto X-VF amber in mine, Morimoto also make a switchback version. I had some issues with the cheap 1157 amber LED so be aware the cheap Asian imports can be problematic. I recently redid the front indicator/running lights with Morris Minor low profile types still set up the same way.
Edited by bikewiz, 16 June 2020 - 01:58 AM.
#3 jemo1
jemo1
    Just On Tickover
  • 9 posts
Posted 16 June 2020 - 02:09 AM
Thanks very much.  I agree LED lights can be hit or miss.  Definitely get what you pay for.
#4 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 16 June 2020 - 02:45 AM
So if you do switchbacks I think what you want is Minispares part 1B9100MS which is a dual filament holder with a clear lens they're only $9 or so, the LEDs will cost more than the holders...
#5 timmy850
timmy850
  • 3,616 posts
  • Local Club: MITG
Posted 16 June 2020 - 11:17 AM
I use them, they work great. Aussie cars have clear lower lenses, and the parking lights there too - at night it's white and flashes white on top which is super hard to see.
You can use these like DRL's at the front - when the parkers are on it's a bright white, then it turns off and flashes amber when the indicator is on
These are the bulbs
There is a video of them working here
https://www.instagra..._web_copy_link
#6 jemo1
jemo1
    Just On Tickover
  • 9 posts
Posted 17 June 2020 - 07:58 PM
Wow Timmy those are bright!  Nice, now I want for sure.
#7 jemo1
jemo1
    Just On Tickover
  • 9 posts
Posted 17 June 2020 - 07:59 PM
Too bad shipping is so much to the U.S. and I just placed an order with Minispares for other stuff.  :(
#8 timmy850
timmy850
  • 3,616 posts
  • Local Club: MITG
Posted 17 June 2020 - 08:24 PM
They’d also have them at the US shops like minimania and seven mini parts
Eg
https://www.7ent.com...c-1b9100ms.html
https://www.minimani...ns-Dual-Element
#9 jemo1
jemo1
    Just On Tickover
  • 9 posts
Posted 24 June 2020 - 04:50 PM
Thanks Timmy.  I just noticed those housings only have 2 wires.  Is it grounded thru the mounting plate?
#10 timmy850
timmy850
  • 3,616 posts
  • Local Club: MITG
Posted 24 June 2020 - 11:00 PM
Yes, they are grounded through the plate into the body
#11 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 09 July 2020 - 09:57 AM
I run a pair from classic leds that switch the side lights off when indicating. I had a set prior that didn’t which made it difficult to see the indicator flashing
