998C Mini Stuttered To A Stop And Now Won’T Start!
20 replies to this topic
#16 samuelsam
samuelsam
  • 12 posts
Posted 18 July 2020 - 04:04 PM
When it is stuttering, is there a change if you apply the choke?
It seems like there is, but only for a short time (a couple of seconds) before it begins stuttering again.
#17 cal844
cal844
  • 9,731 posts
  • Local Club: TFMOC
Posted 18 July 2020 - 05:19 PM
Change the coil for a known working one
Edited by cal844, 18 July 2020 - 05:19 PM.
#18 samuelsam
samuelsam
  • 12 posts
Posted 18 July 2020 - 06:07 PM
Hi cal, thanks for responding. What do you mean by working one? It seems to be working at least most of the time... the problem purely seems to be after a reasonable period of idle
#19 cal844
cal844
  • 9,731 posts
  • Local Club: TFMOC
Posted 18 July 2020 - 06:42 PM
The coil can start to break down, so instead of a 100 volt spark at the plug you get an 80 volt spark at the plug, the 20 volts make a difference and give a misfire and alot of heat
#20 samuelsam
samuelsam
  • 12 posts
Posted 18 July 2020 - 06:52 PM
Thanks. One of the first adjustments I made was to replace the coil, going back a few months now. So this was an issue with the last coil too. Knowing this, do you think it's worth getting a brand new coil, or could the problem be elsewhere? Any chance it could have something to do with the fuel/air mix being off?
#21 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 18 July 2020 - 08:48 PM
When you pull the choke it in effect richens the mixture, so was hopeful that if pulling it out when the problem occurs helped, it would point to a lean mixture.
Have you pulled and checked the plugs since changing them?
