hs4 to hif38
25 replies to this topic
#16 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 30 October 2006 - 04:47 PM
the spacer is for insulation isn't it?
#17 Big_Adam
Big_Adam
  • 7,435 posts
Posted 30 October 2006 - 04:48 PM
aye, suppost to stop heat getting to the carb,
#18 miniboo
miniboo
  • 9,327 posts
Posted 30 October 2006 - 04:51 PM
thought it was the other way round
#19 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 30 October 2006 - 05:25 PM
mg manifolds give more room to play than most because they are quite a short manifold! i think vizzards words were "its almost perfect but about 1inch too short"
torquemaster is the worse for fitment because it tilts the carb up at an angle!! maniflow is pretty much like a copy of the mg in its lengeth and shape!! id use the maniflow for a 998 and the mg for a 1275 purely because the port sizez on an mg are probably a little large for a 998
I like learning stuff... :genius:)
#20 Gizzum
Gizzum
  • 554 posts
  • Local Club: None atm
Posted 30 October 2006 - 08:21 PM
O.K. then so can you run without a spacer or not???
I have a water cooled alloy manifold so can i run without the spacer as my HIF hits the bulkhead underneath the round hole and i would have to do a bit of bulkhead welding to rectify this problem.
For info go for HIF's they are a cracking improvement!!! Easier to adjust and hence easier to set up... no more knackered hand from adjusting the mixture screw
#21 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 30 October 2006 - 09:43 PM
Yes you DO NOT need the spacer when using an alloy inlet manifold.
It was there to help stop heat transfer from the cast iron unit to the carb.
#22 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 30 October 2006 - 11:30 PM
i think that makes the clearance for the throttle arm very close!! depends on the manifold tho i guess!!
#23 stef
stef
  • 799 posts
Posted 31 October 2006 - 01:28 AM
well in that case i guess i'll be fine. if clearance with the throttle arm is an issue i'm sure i can make up a thinner spacer so it still doesnt hit the bulkhead.
anywho i'll post up weather i get hassle with it as and when it all happens lol.
cheers,
Stef
#24 Jimmyarm
Jimmyarm
  • 2,239 posts
  • Local Club: TMf
Posted 31 October 2006 - 09:38 AM
cheers,
Stef
You can buy thinner spacers, its a good idea to get one anyway as they dont cost much and you can guarantee linkage clearance.
Please please dont forget to order shorter manifold to carb studs as well, the standard ones are way too long when you dont fit a spacer.
When I did mine recently, I used a maniflow inlet and the linkage does slightly fowl but I used the original spacer and employed a hammer to bend the bit where the K&N cone baseplate just touched the bulkhead hole.
#25 stef
stef
  • 799 posts
Posted 31 October 2006 - 11:25 AM
anyone got a linky for a thin spacer?
do i need studs like this?
http://www.minispare....aspx?pid=38117
#26 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 02 March 2007 - 05:21 PM
Hi guys
Hijacking this thread (it is relevent)
The 11mm spacers are on back order, the carb does need a spacer even with the shorter studs(you physically cannot get the carb on the studs). I have made a spacer from 12mm plywood, would this be sufficient or do you think it would leak air?
David
