Rough Idle
26 replies to this topic
#16 Mini Manannán
Mini Manannán
  • 2,857 posts
  • Local Club: man Estate
Posted 09 July 2020 - 06:38 PM
Indeed. I've been using SU damper oil for some time but latterly, after the latest mod, the car wouldn't idle properly and wouldn't pick up nicely from low revs. I wicked half the SU oil out and topped up with 20W50, all is well again.
#17 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 09 July 2020 - 09:27 PM
I tried mixing mine 50/50 and my cars still wouldn't accelerate well enough (pulled smoothly but just not quite hard enough)
I ended up having to go all 20/50 and it runs perfect
#18 Mini Manannán
Mini Manannán
  • 2,857 posts
Posted 09 July 2020 - 09:30 PM
Like you said Cal, every car has their own needs.
#19 Chekako
Chekako
  • 19 posts
Posted 16 July 2020 - 05:26 PM
So I got the carb out and I have notice my needle leaning to one side all the time. Pulled it out and noticed that the little sleeve that holds the spring is not completely flat, I cannot see any indentation on the seat that would hold this little outdent.
Also: Is there any gasket that would stop the damper oil from running down the carb?
Edited by Chekako, 16 July 2020 - 05:29 PM.
#20 Chekako
Chekako
  • 19 posts
Posted 16 July 2020 - 05:38 PM
I should add that the needle is in fact straight
#21 Chekako
Chekako
  • 19 posts
Posted 16 July 2020 - 05:44 PM
Also the needle does wiggle around a lot when it's in the sleeve, I suppose that's not good either.
The little outdentation won't allow the needle to fit snug in the sleeve to it pops out and is just held by the spring causing it to wiggle.
Edited by Chekako, 16 July 2020 - 06:02 PM.
#22 Dusky
Dusky
  • 5,322 posts
Posted 16 July 2020 - 08:26 PM
That needle isnt installed correctly.
#23 Chekako
Chekako
  • 19 posts
Posted 16 July 2020 - 08:39 PM
What is the correct way of installing it?
#24 Dusky
Dusky
  • 5,322 posts
Posted 16 July 2020 - 09:27 PM
Take the sleeve, push the needle through it so the shoulder rests on the bottom of the sleeve. Then push the spring on the top of the needle. Then install the combo in the piston, make sure the sleeve sits flush with the piston.
#25 Chekako
Chekako
  • 19 posts
Posted 18 July 2020 - 04:04 PM
I have cleaned everything and it's ready to go back into the car, I'll use 20W50 now.
One more question:
What the hell is this thing that's sitting in my fuel line?
Is that a fuel filter or a pressure stabilization thingy of some sort? I know that there's a little filter at the rear where the fuel pump is, so what's that thing?
Edited by Chekako, 18 July 2020 - 04:20 PM.
#26 DamoMini
DamoMini
  • 40 posts
Posted 18 July 2020 - 05:02 PM
Isn’t that your mechanical fuel pump? Do you also have an electric pump at the rear?
#27 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 18 July 2020 - 05:17 PM
That's a mechanical fuel pump. The car might well not run well if you have an electric pump too... I've never tested it so just a guess
