Spi Power Loss / Hesitation When Cold
16 replies to this topic
#1 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 14 July 2020 - 04:24 PM
Hello
I have a 1993 L reg SPI Cooper
I've changed the following very recently (within weeks / days):
spark plugs
HT leads
distributor cap
rotor arm
fuel filter (and pipes either side)
oil filter
oil
air filter
Within the last 2 years, I've also changed / replaced with new:
all 4 vacuum pipes
fuel trap
coil
thermostat
coolant
oil (2x)
radiator cap
a few coolant hoses
other things I can't recall
The car starts first time, every time
It just pings into life
That's just to give you an idea of what's been done already
Now, getting to the point, finally....
When the car is cold, under even gentle acceleration, the engine loses power and almost cuts out
I have to quickly press the clutch pedal to stop it cutting out
Then tease the revs up with a bit of clutch balancing
Once warm, it runs and picks up fine
And I don't mean "depths of winter -5 degrees cold"
Just general cold start up in this UK July weather
Any ideas?
Distributor?
Not that it's an actual distributor as far as I can tell from my online reading
I am very much a novice with a decreasing amount of skin on my knuckles
I'm enjoying the steep learning curve, but very wary of my limited knowledge and skills
Hoping to benefit from those that know (MUCH more)
Thanks in advance
Regards
#2 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 14 July 2020 - 05:00 PM
Just to clarify / expand on one part of my description, with new words in bold below:
Then gently tease the revs lumpily up with a bit of clutch balancing
Pressing the accelerator harder with gung-ho abandon makes it very unhappy and sends it back into withering mode
#3 genpop
genpop
  • 536 posts
Posted 15 July 2020 - 06:13 AM
Build a connection cable described here:https://colinbourassa.github.io/
 or buy a complete one. Then you need a laptop or handheld.There are some diagnose-programs on the internet like mems gauge, mems-rosco,mems-diag,mems-fcr.Then do a test-run with writing a log file.If you publish that logfile we can try to diagnose your badly running engine.
#4 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 15 July 2020 - 11:22 AM
Thanks. I've read the article and guide from the link. I'll do some more research to be sure it's not completely beyond me, which it might be. If I was to buy a ready made connector cable, is there anything in particular I need to look for? Or do you perhaps have a link for one? Software such as mems gauge...is that free to download?
#5 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 15 July 2020 - 12:05 PM
Is this what I need?
https://www.ebay.co....4-/303464172974
#6 humph
humph
    How bad can it Be?
  • 1,125 posts
Posted 15 July 2020 - 12:48 PM
That's the one.  I posted links to all the software downloads in a post on here the other day.
http://www.theminifo...d-the-software/
Under software here
https://colinbourass...mems_interface/
takes you to this page
https://github.com/c...eases/tag/0.2.0
Mems Rosco here
https://github.com/LeopoldG/mems-rosco
Edited by humph, 15 July 2020 - 12:50 PM.
#7 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 15 July 2020 - 03:02 PM
Thank you. Great stuff
#8 Algordo1100
Algordo1100
  • 774 posts
Posted 15 July 2020 - 05:15 PM
From the symptoms it sounds like it is under fueling when cold. Like pushing your choke in too early on a carb.
From that I'd guess coolant temp sensor is either telling the ECU lies, or isn't saying anything. In which case the ECU assigns a default output for the broken sensor and gives a fault codes.
Get it plugged in. I use my phone and the app I use gives live data from the sensors so you can check easy.
#9 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 17 July 2020 - 03:03 PM
screen data from diagnostic connection
not sure how to share the actual data download file on here
Faults
 MAP sensor fault
Raw data
 Ambient temperature:200 * default value - check *
 Battery voltage:12
 Coil time microseconds:3252
 Coolant temperature:86
 Fault byte 1 bits:00000000
 Fault byte 2 bits:00100000
 Air con clutch fault:false
 Ambient air temperature fault:false
 Boost valve fault:false
 Coolant temperature gauge fault:false
 Coolant temperature fault:false
 Fuel pump circuit fault:false
 Fuel rail temperature fault:false
 Intake air temperature fault:false
 Knock detected:false
 MAP sensor fault:true
 Purge valve fault:false
 Throttle fault:false
 Turbo overboosted:false
 Fuel rail temperature:200
 Idle hotdb steps:10
 Idle setpoint:0
 Idle speed deviation:6
 Idle switch:0
 Idle valve position:0
 Ignition advance offset:0
 Ignition advance raw:76
 Intake air temperature:40
 MAP sensor (kPa):30
 Park/Neutral switch:1
 RPM:840
 Throttle voltage:0.13
 Air/fuel ratio:146
 Cam shaft sync:true
 Purge valve duty cycle:0
 Closed loop:true
 Crank counter:19
 Crank shaft sync:false
 Cruise control:false
 Engine bay ventilation relay:false
 Fan 1 control:false
 Fan 2 control:false
 Engine bay ventilation warning:false
 Hill assist:false
 Idle base position:10
 Idle error:128
 Ignition switch:16
 Injector 1/4 driver:false
 Injector 2/3 driver:false
 Lambda heater relay:false
 Lambda mV:810
 Lambda sensor duty cycle:255
 Lambda sensor frequency:255 (not reporting)
 Lambda sensor status:1
 Long term trim:149
 Short term trim:114
 Throttle angle:5
#10 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 17 July 2020 - 04:12 PM
link to data
https://www.icloud.c...zX37ipc01A#Mini
#11 genpop
genpop
  • 536 posts
Posted 17 July 2020 - 05:01 PM
Which diagnostic tool is it?Can`t you publisch the logfile here? ( More Reply Options-> search your logfile->attach file)
Map sensor fault-> are all connections good replace hoses by silicone ones, replace fuel trap.Delete faults-> do a new log!
#12 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 22 July 2020 - 11:59 AM
Attached File  Diagnostic Data July 2020.pdf   474.54K   18 downloads
#13 Elwyn
Elwyn
  • Just Joined
  • 365 posts
It wouldn't let me upload it as an excel CVs something or other file, so it's here in pdf
#14 genpop
genpop
  • 536 posts
Posted 22 July 2020 - 02:25 PM
No chance to read from a pdf!
Switch to more reply options.Search for your csv or txt.Attach it!
If it is greater than 2MB open it with any a read write programm what is good for csv or txt files.Delete from the end until size is smaller than 2Mb and try again.
#15 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 24 July 2020 - 11:35 AM
Does this link take you to a version of the file that makes more sense?
https://drive.google...iew?usp=sharing
