Set of complete twin 1.25 inch carbs
Posted 30 October 2006 - 01:26 PM
Luke
Posted 30 October 2006 - 01:37 PM
Apparently throttle response can 'improve' and the 'smoothness' of the engine can 'improve', to be honest i've always found it to be negligable.
Maintenance wise, there's a lot of scare mongering that goes on regarding twins, If set up carefully, using ther ight linkages and tuned properly, they are no more hassle than a single SU.
Posted 30 October 2006 - 03:10 PM
if you want some more from your carb might as well get a HIF 38 (?) probly be easyer and better.
Posted 30 October 2006 - 03:16 PM
yeah i asked a mate of mine about twin carbs. he said don't because they a complet bugger to set up.
if you use the correct linkages and balance the oils well enough so you get the same response from each carb they're fine, they're not hard to set up as such, you just need to know what you're doing.
Id second moving to a larger single SU with an internal float, like an HIF38.
Posted 30 October 2006 - 04:18 PM
sorry for hi jacking...
Posted 30 October 2006 - 04:54 PM
ill let my dad know about this thread.. he just got brand new carbs.. any guides anyone would suggest?
guides to what?... best thing to buy for fixing, stripping, and maintenance of SU carbs is the haynes SU book,
Posted 30 October 2006 - 04:55 PM
spot on retro.. didnt know they did one.. thats his xmas present this year then
Posted 30 October 2006 - 04:59 PM
nuff said
Posted 30 October 2006 - 05:00 PM
Posted 30 October 2006 - 06:52 PM
