hi
I discovered today that the left front side of my car was 1cm higher than the right front side, which caused the driving not straight
whats the problem?
thanks
Posted 08 September 2020 - 08:28 AM
hi
whats the problem?
thanks
Posted 08 September 2020 - 08:52 AM
Your suspension rubber cones will likely have compressed over time and the front right likely more so due to drivers weight ... probably time to renew the rubbers.
Posted 08 September 2020 - 10:32 AM
Could be many things. As above or the knuckle has worn through or you may have problems at the rear causing the front to compress or lift,
get it up in the air and look.
