Clutch Arm Push Rod
26 replies to this topic
#16 nicklouse
  • 18,697 posts
Posted 20 September 2020 - 08:46 PM
Nick, you mean I'd to replace this part?
yes and all the pins. you see the ball end. they wear and also bend. and the parts above.
#17 PACINO
PACINO
  • 764 posts
Posted 20 September 2020 - 10:12 PM
Thanks a lot man. You're very kind. Tomorrow I'l take some pics of the clutch to put here. By the way, this part doesn't hear me waching it never fitted in my car.
#18 PACINO
PACINO
  • 764 posts
Posted 20 September 2020 - 10:14 PM
Cheers Nick !
#19 nicklouse
  • 18,697 posts
Posted 20 September 2020 - 11:02 PM
Replace that as well if you can/want needs the cover off and bearing removing and refitting or a new bearing as well.
#20 croc7
croc7
  • 817 posts
Posted 21 September 2020 - 08:25 PM
The Clutch master (metal type) and Slave cylinder (pre-verto type) was fitted only a few months ago in the car, but I didn't feel any improve.
Replace the rubber hose from the supply line to the slave cyl with a stainless steel braided one as well.
#21 PACINO
PACINO
  • 764 posts
Posted 21 September 2020 - 09:45 PM
Hi. In this photo you can see how it came out or unscrewed that I have to have the screw so that the arm is more open. If I allow the arm to go more closed, then the pedal inside the car is not high, the travel is less, and the gears do not enter. Could this be due using a'clutch arm push rod' longer??
#22 PACINO
PACINO
  • 764 posts
Posted 22 September 2020 - 12:32 AM
Yes. It's already steel braided. Thank you Croc !
#23 PACINO
PACINO
  • 764 posts
Posted 26 September 2020 - 06:18 PM
#24 croc7
croc7
  • 817 posts
Posted 27 September 2020 - 09:29 PM
After you’ve replaced the pins, lever, plunger and this pushrod, set the gap to .015“-.020“, adjust from there. Assuming hydraulics are OK, should be fine, keep us informed.
#25 PACINO
PACINO
  • 764 posts
Posted 28 September 2020 - 12:35 AM
I've just to see this answer. Thanks for your help Croc !
Regards, Luis
#26 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 01 October 2020 - 03:59 AM
The clutch slave only has a limited range of movement when you press the pedal. The adjustment on the stop bolt needs to be very close to correct or the slave will be taking up the slack in the system first before moving the arm.
The clutch arm needs to be on an angle toward the clutch cover in order to get enough travel out of a standard length pushrod. If your arm is starting at a wider angle, this would suggest wear in the bottom clevis pin, clutch cover, plunger or clutch arm. You can also pull the dust boot off the end of the slave cylinder to check that the piston isn’t reaching the end of the travel when the pedal is depressed.
If you change from a long pushrod to a shorter one with no other changes I’m guessing the slave will run out of travel and won’t disengage the clutch
Here is an example of how it should all look
Attached File  E78AB676-D285-4847-9E84-6587C4ADD025.jpeg   34.74K   0 downloads
I’d also check:
Fluid is bled (you can remove the slave from the gearbox and hold it above the master to help bleed)
Clevis pin on the clutch pedal has no wear and the hole isn’t oval on the pedal or pushrod
#27 PACINO
PACINO
  • 764 posts
Posted 05 October 2020 - 08:59 AM
Hi Timmy! I just saw your answer. Cheers man, the photo is magnificent. So far, I've not bought a new clutch arm, which may have the ball worn as colleagues have told me in this post. The clutch master cilynder, the slave cylinder, and the metal hose are new, and I just replaced the clutch push rod which was worn as well as the pin. Outcome? Well, the clutch pedal route is a little shorter, but it is smoother and the gears don't scratch, but this is not perfect. So when I can, I plan to renew the arm.
Regards
Edited by PACINO, 05 October 2020 - 09:02 AM.
