10 inch wheel fitment.
Posted 30 October 2006 - 11:32 PM
I am going to be fitting the later hubs with 8.4" discs milled down to 7.9" with mini sport 4 pots. will this set up keep the wheels within the wings? or is a cooper s set up needed ( i dont really want to have to revert to this i have build up hubs and disc etc...)
Also on the rear will i fit spacered or non spacered drums to keep the wheels where i want them?
Any advice appreciated,
Daniel
Posted 31 October 2006 - 10:22 AM
Posted 31 October 2006 - 11:44 AM
Not sure what the offsets are of the two disc assemblies, but I believe both maybe the same, and so with 4.5 S reverse rims you shoud be ok.
I know that when I went from my Cooper S assembley, to a 8.4" set, machined down to 7.9" with KAD 4 pots, the track of the car stayed the same.
Posted 31 October 2006 - 11:53 AM
Posted 31 October 2006 - 12:07 PM
I can get the minisport 4pot alloy caliper set up using 7.9 discs for about the same price as converting to 7.5 cooper s items, so thought this would be a better choice the braking potential is greater and they look alot nicer.
Thanks for the responses
Dan
Posted 31 October 2006 - 12:15 PM
I've fitted reverse S rims over disks and have been lucky to get away with it, they stick out about an inch and it's not an MOT issue, having your wheels sticking out, as it does not form part of the test... it's a legal one, ie the police can stop you and give you a fixed penalty there and then.
Posted 31 October 2006 - 12:55 PM
Final question, Do i fit spacered or non spacered drums?
Daniel
Posted 31 October 2006 - 12:59 PM
Posted 04 November 2006 - 12:06 PM
with the extra track at the front from the disc's it would be beneficial if you fitted the spacered drums to keep your handling sharp!
Ok this is def my final question on the matter......
I think it will be benefical for ease of fitting all kinds of 10inch wheels to fit 7.5" discs and the matching flanges. Ill later decide on either the standard 7.5" calipers or go over kill and get some sexy Alloy 4pots.
Would the fitment of the 7.5" discs and flanges decrease the track width of the wheels or was it just the drum brakes that had the narrow track. (again im unsure of spacered or unspacered drums for the rear with the 7.5" brakes)
Daniel
Posted 04 November 2006 - 12:32 PM
Posted 04 November 2006 - 06:51 PM
Posted 04 November 2006 - 09:31 PM
I thought Cooper S reverse rims had the offset that allowed you to have disc brakes without the need for arches?
Thats what i thought but also thought the 7.5" brakes sat further in than 8.4" set up but i was wrong about that also.
Tim Mundy in this months mini world answered a question about tyre sizes and said the 165 x 10 tyre aparently sits outwidth the wings but the 145 x 10 tyre sits within the wing.
Anyone else heard of this?
Daniel
Posted 04 November 2006 - 09:41 PM
Posted 05 November 2006 - 09:06 AM
I am running 8.4" discs, so spacered rears as standard.
Image @ http://www.theminifo...x...st&id=19566
Edited by Jordie, 05 November 2006 - 09:08 AM.
Posted 07 November 2006 - 04:45 PM
