Repairing my mini
Posted 31 October 2006 - 01:46 AM
My mini had accident damage off-side rear when I bought it, which I fixed with the help of a large hammer. it's has MOT for six months, so I will have to repair the damage correctly befor it expires.
Basically I need to fit quite a few new panels to the rear, including the rear offside internal wheel arch.
May also replace stills and floor, as i don't really like the dodgy repairs which had been done by a tool.
Does anybody know any dimensions to build a frame to support the chassis, to hold everything together and make sure it's all straight and true.
Thanks for your help
Richie
Posted 31 October 2006 - 02:17 AM
As fair as I am aware as long as there is nothing protruding that could catch on another car or pedestrian then you should be fine. If there is jagged metal pointing out, you're gonna need to get that sorted before you go for your MOT
Posted 31 October 2006 - 03:05 AM
interior rear offside wheel arch.if
outer rear offside wheel arch.
rear bottom panel.
boot floor repair panel.
rear repair panel from the rear window down.
Posted 31 October 2006 - 07:19 AM
These are not separate panels. It is one complete panel.
If the car has had this amount of rear end damage, was it an insurance write-off?
Why do you need a frame just to replace the panels listed above?
Edited by minislapper, 31 October 2006 - 07:21 AM.
Posted 31 October 2006 - 09:48 AM
Posted 31 October 2006 - 10:02 AM
Posted 31 October 2006 - 12:07 PM
I paid £110 T+T for 6 months with no repairs done.
some photos of the damage as it is now. i put a new second hand boot on, i had to cut thr old one out with and angle grinder! it was pushed inside the boot.
Posted 31 October 2006 - 06:25 PM
i flipped it on its side and in the progress of removing the old ones,also sorting out the non-exsistant rear-subframe front mounts.im doing it one side at a time.
Posted 31 October 2006 - 10:01 PM
not the easiest place in the world to patch up but it is necesary!!
Posted 31 October 2006 - 10:57 PM
Posted 31 October 2006 - 11:19 PM
its worth checking out tho!!
Posted 01 November 2006 - 11:10 AM
found this site has anyone used it?
https://www.plminishop.com
thanks people
Posted 01 November 2006 - 11:40 AM
Posted 01 November 2006 - 11:41 AM
http://www.moss-europe.co.uk
Edited by Total Richie, 01 November 2006 - 11:42 AM.
