I have a 1987 Mini Advantage with a 1275 out of (what I understand was) a 1985 MG Metro. It went into climate controlled storage in late 2017 and I just got it back a couple weeks ago. Prior to storage it tended to run a bit rich, but nothing crazy. While in storage it was occasionally started and allowed to idle for awhile, but was rarely ever driven out on the road; a friend was graciously storing it for free while I was abroad, so I can't complain too much.
Since I got it back it starts fine but it was immediately clear that it was running extremely rich, like black plumes of smoke when I hit the throttle rich. I haven't done much just yet, I know I need to do a valve adjustment and check the timing, but I was hoping to at least lean it out a bit to stop spewing black smoke whenever I have to let it run. Last night I hooked it up to my Gunson Gastester, which I know is a deeply fallible instrument but I wanted to at least try and get it into the ballpark of a good AFR, and I discovered that no matter how I adjusted the mixture screw on the side of the HIF44, the Gunson never changed, and there was very little change to the idle (which I had set at about 950). Similarly, the black plumes were the same no matter where the screw was. As you might expect, the plugs are as black as night. Looking at the car again tonight, I noticed the oil absolutely has fuel in it.
In terms of past work I've done, it's pretty minimal as it's always been pretty reliable. I had to replace the fuel pump, which I did with another mechanical one, about 7 or so years ago, I needed the tropical fan and a new radiator about 5 years ago, but that's about it. I've had it since 2012. As I said, I know I need to do basic tune-up stuff before I dig in too deep, but the fact I couldn't get it down from its super-rich mixture was pretty concerning. That said, I wanted to throw it out there and see if this issue immediately brought anything to anyone's mind, especially in light of two years of storage. Things that I have considered are a carb service kit, getting a compression test kit and using it, and valve seal replacement. But obviously I don't want to just shotgun parts at it.
Any advice is greatly appreciated!
EDIT: Found some older posts regarding somewhat similar issues and a couple of them pointed to the o-ring on the choke, so I popped mine off. As you can see in the image it's...terrible. I have to imagine every other service item in the carb looks about the same.
Edited by sdjones121, 07 October 2020 - 12:56 AM.
