New Rear Subframe Advice
7 replies to this topic
#1 MatthewsDad
MatthewsDad
  • 903 posts
Posted 25 October 2020 - 09:58 AM
Hi, I'm looking at replacing my rear subframe. There seem to be some shortages in the market - M Machine are out of stock, for example. Just looking for advice on where to source the best fitting kit as some suppliers don't indicate who the manufacturer is. Bit wary about some of the fitting problems I've read about on the forum. Heritage a potential but more expensive option.
Also, stupid question, do the fitting kits provide everything I'll need, or is there anything else I need to keep an eye on when refitting?
Thanks.
#2 richmondclassicsnorthwales
  • 942 posts
Posted 25 October 2020 - 10:32 AM
This will open a can of worms - and probably leave you scratching your head with still no direction to go in
Anyway - my thoughts - a lot of the junk is now gone. The subbys you used to see outside the motorists shops - propped up the walls - gone.
You shouldn't have much of a problem if you buy from a reputable supplier - Heritage or not. I found the after-market subframes heavier than the Heritage, and a good deal of weld applied.
Rear fitting kits are available to buy complete - I used to sell them when we were UK based along with front subframe fitting kits or complete rear and front kits, but yes rear kits are available.
The real problems I found was that if the rear heel board had been replaced - and not set and fitted correctly - this gave the Mini it's crabbing effect - along with a spurious subframe from Jo Bobs Autos. As I say most of these makers have gone now, leaving the reputable firms
You will be hard pressed to get a manufacturers name from a supplier of subframes
That's my two pennies worth anyway. Buy from a good supplier - take your time fitting - and you will be fine.
#3 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 25 October 2020 - 11:20 AM
As above you'll only get a subframe that will fit. What I will add is to consider getting radius arms refurbished and a new Bush kit.
Also consider adding some welds to add additional strength. Then paint it in 2k gloss black (or any colour you wish) for added protection.
Whilst the subframe is out make sure the body around it gets corrosion checked, painted and protected.
Hope this helps
Regards
Cal
Edited by cal844, 25 October 2020 - 11:23 AM.
#4 GT Jimmy
GT Jimmy
  • 1,676 posts
  • Local Club: S.U.N.M.C
Posted 25 October 2020 - 11:21 AM
I fitted a non genuine frame with no issues, however a lot of people will frown upon this. Maybe I got lucky
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 October 2020 - 11:33 AM
I have a non genuine rear frame to go into a customers car right now and using it initially to check for fit when replacing the panels looks good.
I had to slightly enlarge the holes on the front of the frame for the trunnion pins but everything looks fine.
I've not fitted the frame up with rear arms etc but should be fine
I was reading about some frames not being well finished but this one is great compared with the rubbish you used to see.
Just strip it back and paint it properly with decent paint.
As for suppliers, this one came from bull motif
#6 MatthewsDad
MatthewsDad
  • 903 posts
Posted 26 October 2020 - 07:28 AM
Thanks everyone, great advice.
#7 KTS
KTS
  • 2,490 posts
Posted 26 October 2020 - 02:49 PM
when it comes to fitting, and as Ben noted above, trial fit the the front trunnion pins to the subframes without any bushes to check the shoulder below the threaded portion does butt up against the panel it goes through
can also help to with fitting to only tighten trunnion pins nuts after the heelboard mounts have been bolted up - does mean you'll have to fit the radius arms after the subframe is attached though...
#8 bpirie1000
bpirie1000
  • Area Managers
  • 2,571 posts
  • Local Club: Amoc
Posted 26 October 2020 - 04:40 PM
Give it a weeks worth of lubrication and penetrating oil before you start..
Plus gas is so look much better than wd-40 (water disperent)
