Speedometer Question Swift G13B
5 replies to this topic
#1 ilmung
ilmung
  • 40 posts
Posted 26 October 2020 - 12:04 PM
I do a conversation " Mini Midas with Swift gti 1300" and I wonder if the speedsensor in the Swift speedometer is really necessary to let the engine run without any problem ?
I mean if I use  the speedometer of the Mini Midas ,which is coming from a Metro car , will I have problems with the engine ?
#2 DomCr250
DomCr250
  • 613 posts
  • Local Club: 16V mini club
Posted 01 November 2020 - 09:29 AM
No, you don't really need it.  It's supposed to help with running but in reality does not make any noticeable difference.
You can still fit it if you really want to, you've posted on the 16v mini club forum too - just search on 'swift speedo sensor' and you'll see all the replies.
#3 ilmung
ilmung
  • 40 posts
Posted 01 November 2020 - 10:09 AM
Hi DomCR250, thanks for the reply !
I have got some answers from different forums and it seems that you don't really need the speedsensor , but nobody could tell me the real  function
of this speedsensor ?
Some people make a kind of reed contact or hall effect contact .......but I do not understand that they  do such an effort  for something which is not necessary ?
#4 DomCr250
DomCr250
  • 613 posts
Posted 01 November 2020 - 10:39 AM
The VSS (Vehicle Speed Sensor) is just that, it tells the ECU the vehicles speed, I had to do a quick google as it was over ten years ago when I looked into this ...found this that might help on RedlineGTI...
the only purpose of the vss in the gti is to control the idle solenoid valve
Yes, it is a simple reed switch.  You could buy one for pennies, stick it as close as you can to the disc / magnet that rotates inside your speedo and it will function the same as the Suzuki OEM one. Easy to test and set-up with a multimeter, as it's just an on/off circuit.
I used the complete swift loom and dash cluster, just attached the mini lights and wiper to that loom, but thats of little help to you I suspect.
#5 ilmung
ilmung
  • 40 posts
Posted 01 November 2020 - 01:02 PM
I just register me on the Redline gti forum, thanks for the info !
#6 ilmung
ilmung
  • 40 posts
Posted 01 November 2020 - 01:23 PM
I just read about the function of the ISC .The function is to adapt the idle speed in different circumstances ( thermo fan is going on , airco on/off  ,lights on/off, etc.........)
Some  people mention that there is a  little variation in idle speed when the ISC is not used .
But I will try the reed contact .
Mini Spares
