Ball Joint Splitter
12 replies to this topic
#1 Maccmike8
Maccmike8
  • 1,101 posts
Posted 26 October 2020 - 12:17 PM
Hi, can somebody recommend a ball joint splitter for lower arms?
Thanks Mike.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 26 October 2020 - 12:21 PM
I use one of these types http://www.minispare...|Back to search
#3 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 26 October 2020 - 01:42 PM
I use a steel fork type splitter with a longer handle.
#4 richmondclassicsnorthwales
  • 942 posts
Posted 26 October 2020 - 01:46 PM
Same as Cal - 2 pronged fork - works a treat - never failed on splitting a joint once
#5 Icey
Icey
  • 1,586 posts
Posted 26 October 2020 - 01:55 PM
I've got three main types - fork, small threaded press, larger scissor press (excuse the Halfords links, no doubt there will be better options than Laser). Of the three I tend to use the middle one the most because it fits nicely around the end of the lower arm.
Sometimes none of them work and all that shifts it is a big hammer to the side of the arm.
#6 Maccmike8
Maccmike8
  • 1,101 posts
Posted 26 October 2020 - 02:25 PM
Ive bought the Minispares type one but from Halfords, will see if it works.
I have one of those long forked types but find it splits the rubber boots - granted I havent used it on the Mini though.
#7 Icey
Icey
  • 1,586 posts
Posted 26 October 2020 - 03:56 PM
I bought one of those for doing the ball joints on our BMW Minis and found the same, but, to be honest, if I'm that far into that kind of job I'll just replace the joints while I'm there. (I had to buy a 4kg lump hammer for the same reason - they don't come out easy).
Edited by Icey, 26 October 2020 - 03:57 PM.
#8 bpirie1000
bpirie1000
  • Area Managers
  • 2,571 posts
  • Local Club: Amoc
Posted 26 October 2020 - 05:15 PM
Buy the hammer before the splitter...
Always makes you feel better bashing things.....
#9 Dusky
Dusky
  • 5,322 posts
Posted 26 October 2020 - 05:31 PM
I use this type : http://www.minispare...50.aspx|Back to
For multiple reasons. Dont have to hammer ( no risk of slipping of jack stands), and presses in the right direction. Scissor types always lose some force in side loading.
#10 Spider
  • 15,879 posts
Posted 26 October 2020 - 07:17 PM
I have a couple of this style, one in a Club brand and the other in a Sykes. The Club one I've had for about 35 years and is starting to show the amount of use it's had, so I bought the Sykes one about 5 years back for the day when the Club finally gives up.
I also have a long Fork Type that I use if I'm replacing joints (or Rubbers) or if I get a really stubborn one.
These are pretty good, but really, only light I found. On Ball Joints, I found it would do less than 1/2 of them. If it's something that's been together a few years, forget it. You have a good point about the side force from the Scissor type though.  I use this one on the Steering Rod Ends now and  that's all.
#11 weef
weef
  • 559 posts
Posted 26 October 2020 - 09:47 PM
Its horses for courses. In the workshop we use 6 different types. Two sizes of the fork type, for differing diameters of pin, but as said this type usually destroys the rubber boot. Next we have the cup type , but care has to be observed to not damage any threaded pin, we use this mainly where a cotter pin holds the joint in place, then we have 3 types of scissor splitters. All the scissor types are Sykes units and very good in terms of longevity all being in excess of 20yrs and all frequently used. The smaller scissor type used on the joints found on motorcycles/quadbikes, then their standard size type for general car and light commercial use. Finally we have a larger scissor type with a hydraulic ram to apply the pressure this being used mainly on 4x4 and light commercials.
For general car use its the standard scissor type from Sykes that is the "go to" one every time. A good quality tool that will not let you down and can take some abuse.
Of course other makes of splitter are available.
#12 will_nic
will_nic
  • 104 posts
Posted 06 November 2020 - 06:07 PM
I've got the Halfords scissor type ball joint splitter and it works great, never had any issues. I tend to load up a bit of pressure then give the joint a few taps on the side with a mallet and it'll pop right off.
#13 Maccmike8
Maccmike8
  • 1,101 posts
Posted 06 November 2020 - 06:51 PM
I bought the scissor type from Halfords.
Really good to use. Wish Id bought one years ago instead of the fork type you hit with a hammer.
