12g295
Posted 01 November 2006 - 01:08 PM
Also it needs some cleaning up as the person I bought it from must have had it in their garage for quite a while.
Is there anything else that I should do to it before fitting it?
I'll also be fitting a new exhaust, ex manifold, inlet manifold and carburettor needle. Are there any other parts that I need to change in order to fit the new head or will it go on as is?
And, out of curiosity, what sort of power and torque can I expect?
Posted 01 November 2006 - 11:07 PM
while the head is off it would probably pay to take the valves out check the seats and have them lapped back in or re-cut or even have unleaded seats presed in!! and even check out the guides arent worn while you're at it!!
i know i would do the above!! if i didnt know the history of it!!
Posted 02 November 2006 - 12:21 PM
nothing states that it HAS to be skimmed!! it should bolt straight on!! if you're not sure how much has been skimmed off it before then i would personally just get them to skim it over to make sure its flat!!
Should any engineering shop be able to do those things or is it best left to a specialist?
Posted 02 November 2006 - 06:07 PM
Posted 03 November 2006 - 09:58 AM
Posted 03 November 2006 - 10:03 AM
Posted 03 November 2006 - 07:37 PM
