How Much Gear Wear Is Too Much Wear
6 replies to this topic
#1 1963MKI
1963MKI
  • 163 posts
Posted 27 November 2020 - 07:32 PM
Ive sourced a 3.2 cwp to go into my mk1. The crownwheel appears in good condition. The pinion has the tiniest wear mark on it on one tooth, and im starting to wonder should I replace it. The car is only a sunday driver so I wont be doing a lot of miles. itll be pushing about 70hp but I am spending quite a bit on the engine and box rebuild so I want it to be right.
What do people think ?
#2 MiniMadRacer
MiniMadRacer
  • 850 posts
Posted 27 November 2020 - 07:57 PM
Ideally it should be replaced... if it breaks a tooth off it will probably wreck the crown wheel, and it floats around the g box and gets "picked up" by any of the other gears it will do catastrophic damage.But I confess, I would clean it up and use it...but I would not recommend others too
#3 KTS
KTS
  • 2,271 posts
Posted 27 November 2020 - 08:23 PM
I'd replace if you can - the cost in time and money to replace at this point in the build will be a small fraction of what it would be if it failed when in use.
Might just be the photo, but the 2nd tooth back looks like it's rusted/pitted?
#4 Cooperman
  • 23,039 posts
Posted 27 November 2020 - 08:28 PM
I've seen much worse and I would probably put that into an 850 or a 998, but in a 1275 I would think twice.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 27 November 2020 - 08:53 PM
Replace it.
Ac
#6 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 27 November 2020 - 10:49 PM
If you end up buying the crown wheel and pinion new then you'll more than likely have to get the bearing diameter ground/machined on the crown wheel as they are oversize by 0.1mm from memory.
#7 Spider
  • 13,930 posts
Posted 27 November 2020 - 11:57 PM
That's gone through the Case Hardening. It's karput.
