New Engine Struggling Under Load
20 replies to this topic
#16 Earwax
Earwax
  • 606 posts
Posted 30 November 2020 - 12:47 AM
Fuel   --  you are concentrating on this area , with lots of advice
Air     - i would take it for a run without any air filter just to eliminate oxygen starvation,, but again your methods seem fine
Spark   -  don't assume anything here.  I have spent too many hours faffing around because i assumed plugs and gap, leads, and importantly condenser or electronic ignition were all new and therefore ok.  You may have to substitute for a known good working dizzy to check the electonic ignition. Good luck
#17 johnR
johnR
  • 2,322 posts
Posted 30 November 2020 - 10:36 AM
What colour are your plug deposits?
#18 richmondclassicsnorthwales
  • 942 posts
Posted 30 November 2020 - 11:19 AM
I have never gone in to needle profiles. One thing I can send you is a comparison chart which maps different needles. Hope this helps.
http://www.mintylamb.co.uk/suneedle/
#19 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 30 November 2020 - 12:06 PM
Just to clarify my timing of 12 degrees was carried out using a timing light with the engine running and the vacuum advance disconnected and blanked. The setting is basic to get the engine running before heading to a rolling road.
For info, with the spec of the my engine I mentioned, on a rolling road session it produced 78 BHP. Standard plugs and air filter fitted..
#20 AndrewT
AndrewT
  • 147 posts
Posted 30 November 2020 - 04:23 PM
Put a BDL needle in then re-adjusted the mixture.  Made a massive improvement.  Still a little hesitancy under throttle but at least it's driveable enough to get it run in before a rolling road session.
#21 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 30 November 2020 - 06:43 PM
If its still hesitant it still needs fuel IMO BUT without driving the car I can't be 100% sure
