Heating Hose Diagram
7 replies to this topic
#1 SirBallD
SirBallD
  • 36 posts
Posted 30 November 2020 - 09:19 PM
Hi Mini-mates,
I'm doing a complete restoration of my classic mini 1979.
As a part of this restoration, I'm replacing the engine from a poorly built 998cc A-series (long story) to a 998cc A+ series engine, with a lead free CAM4810 head. I'm currently doing a complete refurbish of this engine.
The issue is that the cylinder head has no hole for the heater valve at cylinder 4. So now I have to redo the heating hoses. I need to replace all the hoses anyway as the hoses are old and brittle.
Does anyone have a diagram of the hoses needed and where they go from and to, for a configuration similar to mine.
I have a heater inside the cabin with inlet and outlet.
No hole for heater valve in cylinder head at cylinder 4.
Water pump without bypass hose and I have a thermostat sandwich plate.
I have bought an inline heater valve for this, but I'm still unsure where this will go.
If someone can make a drawing to explain this to me I would appreciate it greatly. Pictures of similar configurations would also help  :-)
Thank you very much in advance.
Best regards
Stefan  :D
#2 nicklouse
  • 17,945 posts
Posted 30 November 2020 - 09:53 PM
Drill it out and run the hoses as original. 15 or 16mm drill will do.
#3 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 30 November 2020 - 10:21 PM
The bore dimple on an undrilled head is 1/2inch drill size. I just matched the size that was on the head.
The two fixing stud holes should already be threaded ready for the valve
#4 SirBallD
SirBallD
  • 36 posts
Posted 01 December 2020 - 06:11 PM
It seems like there is only the center hole which is not drilled all the way through. The two fixing stud holes are not present  :unsure: not even an indication of where they should be.
I guess I have to give it a shot and drill the holes, trying not to fudge everything up  :whistling:
Edited by SirBallD, 01 December 2020 - 06:12 PM.
#5 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 01 December 2020 - 07:53 PM
The holes should be there for the small studs to screw into, perhaps they have been painted over or filled with crud?
#6 SirBallD
SirBallD
  • 36 posts
Posted 01 December 2020 - 10:54 PM
Cal844, I agree with you as I've never seen a cylinder head without all three holes. This must be the first, unless if the previous owner have welded it up and then skimmed it  :rolleyes: .
Attached File  cylinder head CAM4810 no water2.jpg   59.66K   1 downloads
I have another CAM4810 cylinder head with all the holes and outlet for bypass hose.
Unfortunately it has a damage between the valves. I'm unsure if I should have it welded or if I should grind it and make it similar on all four cylinders. It's a very small area and I assume that it doesn't make any difference to the overall performance of the engine.
Attached File  Cylinder head small damage1.jpg   31.45K   1 downloads
Should I go for the slightly damaged cylinder head, with all the holes and forget about the "no hole cylinder head"  :D ?
#7 nicklouse
  • 17,945 posts
Posted 01 December 2020 - 11:01 PM
That is odd.
ok let’s say you want to use that head as is.
you will need a sandwich plate with a take off to go under the thermostat housing. That take of is the heater feed.
thermostat goes between sandwich and housing.
#8 Ethel
  • 25,416 posts
Posted 02 December 2020 - 01:01 AM
You could blend that broken nose out to good effect, but it'd be more work 'n cost than just sorting the heater take off.
If you can lay your hands on a pillar drill it wouldn't be hard to drill & tap stud holes using a heater valve as a template, or you could acquire a sandwich plate from DSN or one of the other usual culprits. Be aware there'll be a mismatch in hose bores, but nothing you can't sort. Your Min will have been 1/2", later ones used 5/8".
