Spin-On Oil Filter Conversion Problems
24 replies to this topic
#16 ryanlogsdon
ryanlogsdon
  • 110 posts
Posted 08 December 2020 - 04:58 AM
The 'Double Nut' method of Stud removal is a very good one, I use it very often on just about all studs, perfect way to get them out or in with no damage at all.
However, and I have no answer as to why, but these particular long studs I've never had success removing them by this method. I may well have been the ham fisted guy on our lines fitting them in such a way, by all means, try the double nut method first. I think the factory also used a sealant on these threads as the holes do go through to the inside of the crankcase.
When I fit the studs in these holes and also those for the fuel pump, I do use a sealant on the threads, if for no other reason than insurance.
For when I try this out tomorrow, do you go clockwise (looking towards the engine, just like in the pictures above) to remove the stud?
I've watched a few videos, and some release clockwise and others go counter.
#17 Spider
  • 15,873 posts
Posted 08 December 2020 - 05:09 AM
Anti-clockwise when looking at the stud.
#18 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 08 December 2020 - 09:14 AM
Good idea about thread sealant. I've removed the long studs to fit the filter head with shorter bolts. Will add sealant!
#19 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 08 December 2020 - 09:15 AM
"Lefty-loosey, righty-tighty" ... rotate left to loosen, right to tighten.
#20 OzOAP
OzOAP
  • 401 posts
Posted 08 December 2020 - 12:34 PM
Lefty Lucy? I know her...wore dungarees, knitted her own yoghurt and hated men!
#21 ryanlogsdon
ryanlogsdon
  • 110 posts
Posted 08 December 2020 - 09:33 PM
I saw one righty-loosey video and thought *yep, let's double check first*. turns out she's regular ol' lefty loosey
Edited by ryanlogsdon, 08 December 2020 - 09:39 PM.
#22 ryanlogsdon
ryanlogsdon
  • 110 posts
Posted 08 December 2020 - 09:39 PM
Thank you guys!
I couldn't have done that without your help.
Now I need to go to the store and get 2 bolts because the ones in the kit are a little more narrow than the original studs.
Thanks,
Ryan
#23 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 08 December 2020 - 09:50 PM
Great to see you have the conversion done!
If you ever find yourself asking questions just post on the forum as there's never a silly question. The fact you think you should ask should be enough to post 😊
Regards
Cal
#24 ryanlogsdon
ryanlogsdon
  • 110 posts
Posted 08 December 2020 - 09:51 PM
Regards
Cal
Thanks Cal!
#25 Carlos W
Carlos W
  • 10,115 posts
Posted 09 December 2020 - 09:24 AM
Regards
Cal
Exactly this
