High Idle/stuttering When Throttle Pressed Quickly
41 replies to this topic
#31 Mayfair94
Mayfair94
  • 63 posts
Posted 30 December 2020 - 02:49 PM
Further look into this today, I got access to the top of the throttle pedal and found a bracket loose. I’m now thinking do the loose bolt up and the pedal should have something solid to use as a stop for idle. Re-do the adjustment on the cable and then see how my idle is?
Attached File  26EDEB3B-A26F-4038-9499-3804BEB515F5.jpeg   64.98K   3 downloads
Note for some reason the photo is the wrong way around. Pedal arm should be pointing up.
Edited by Mayfair94, 30 December 2020 - 02:50 PM.
#32 andrewdjackson
andrewdjackson
  • 25 posts
  • Local Club: Basingstoke Mini Owners Club
Posted 15 January 2021 - 09:03 AM
As a Mac user there is MemsFCR (https://memsfcr.co.uk) which works for Mac and Windows
#33 brivinci
brivinci
  • 1,210 posts
Posted 22 January 2021 - 07:40 PM
Awesome! Of course it requires the latest version of OS and I am not allowed to update till my company vets it fully. I guess I will have to wait a bit long. sigh
#34 andrewdjackson
andrewdjackson
  • 25 posts
Posted 25 August 2021 - 12:41 PM
A diagnostic application for MacOS is available here: https://memsfcr.co.uk
One other thing: so I am a lifetime Apple user which doesn't help that all these diagnostic programs are Windows based. Compete user error but I was only able to get things to run and log using an old Samsung phone my father was getting rid of. All that said, that is what I used to see the above readings. Came back in and saw that rovermems.com now works with Mac so I gave that a go. Hooked and checked the TPS and readings only go as high as .995v, with a low of .12 BUT seems to sit at .25v unless I snap the throttle closed.
Why on earth would I get such a low TPS volt reading using a laptop vs using a phone. Same cable. Maybe there is something up and your TPS (although still sticking) is giving the correct voltage reading, especially given the 5v supply you tested.
Edited by andrewdjackson, 25 August 2021 - 12:42 PM.
#35 MatthewsDad
MatthewsDad
  • 822 posts
Posted 25 August 2021 - 08:25 PM
Has anyone tried to repair a TPS? I recall reading a thread about cleaning deposits off the inside of the sensor, but not sure whether this was on TMF.
#36 Carvell
Carvell
  • 316 posts
Posted 26 August 2021 - 05:37 AM
Just read the thread, this all makes very interesting reading. Thank you for documenting so well.
#37 genpop
genpop
  • 530 posts
Posted 26 August 2021 - 06:00 AM
Not repairing but building an adapter.
You may buy an adapter like this on the japanese market but damned expensive.
Edited by genpop, 26 August 2021 - 06:02 AM.
#38 Gabor
Gabor
  • 25 posts
  • Local Club: Mini Club Hungary
Posted 26 August 2021 - 10:24 AM
HI,
Looks awsome. IWhat is the type of the sensor? The adapter looks awsome. it is the japanese one or you built it?
Thx
G
#39 genpop
genpop
  • 530 posts
Posted 26 August 2021 - 11:26 AM
This was done by an other user, he printed it in 3d, but alumium is a good solution.The poti is from a later rover, but I think a lot of common TPS will fit too.The problem is the connection between throttle bar and poti.Here is a picture of the japanese parts.
#40 sonscar
sonscar
  • 3,047 posts
Posted 26 August 2021 - 12:59 PM
Adaptors are relatively easy to make with common sense and some hand tools but the TPS can be had in clockwise and anticlockwise rotation so beware when sourcing one,Steve..
#41 Gabor
Gabor
  • 25 posts
Posted 27 August 2021 - 06:43 AM
Steve,
Thank you so much for the valuable information! :) CAn you tell me wich is the correct TPS to source?
Gabor
#42 sonscar
sonscar
  • 3,047 posts
Posted 27 August 2021 - 08:42 AM
Unfortunately not,My experience was with an elderly Rover V8 with a standalone ECU which can be calibrated to almost any  TPS.I would try with a 90s rover product such as 200s,400,mgz etc.Steve..
