0.007 Crankshaft Endfloat (1330Cc)
Best Answer OzOAP , 23 December 2020 - 06:03 PM
Use one side, leaving 0.004 clearance.
Go to the full post
Posted 23 December 2020 - 05:02 PM
After some advice on crankshaft endfloat if any of you chaps wouldn't mind helping.
Just fitted the crankshaft with new standard thrusts and found the endfloat to be 0.007" so have now ordered a set of 0.003" thrust washers.
My question is, do I fit 1 side of oversized to leave me with 0.004" endfloat or both to give me 0.001"?
I was thinking of fitting both and using wet and dry on the backs of the thrusts to get 0.002" clearance.
What are peoples thoughts?
Cheers,
Posted 23 December 2020 - 06:03 PM Best Answer
Posted 23 December 2020 - 07:07 PM
..out of interest; would you use the thicker set on the side the clutch pressure works against or does it not matter ?
Posted 23 December 2020 - 07:21 PM
Posted 23 December 2020 - 07:31 PM
thanks. good point on the crank/cam sprocket alignment
Posted 24 December 2020 - 07:15 AM
Thank you, much appreciated! Will stick with one side only.
