Hi,
Done a quick search and not got definitive answer to this for my situation:
Mpi mini currently in rebuild with strengthening mods done as per Vizard to the subframes.
Plan is to solid mount subframes, engine build approaching completion and starting to build subframe up including mounting the engine so it's all ready to go back into the car from underneath when the body is ready.
Question is what engine mounts, standard or anything better to use?
Thank you
Paul
