Bearing#
Posted 02 January 2021 - 05:53 PM
Posted 02 January 2021 - 06:03 PM
Posted 02 January 2021 - 06:23 PM
Do they need refurbing... if so would a threaded stud, strong washers and nuts work?
Posted 02 January 2021 - 06:43 PM
Just drift them out after having removed the grease so you can see what you are doing.
Posted 02 January 2021 - 06:47 PM
Some photos are missing but you get the idea
Well today was a day of sorting out a few little things. One thing that I have seen is people struggling with top arm bearing replacement with some really odd suggestions including welding bit to the bearing. I guess this is because people have not cleaned out the old grease first. There is loads of room to get a drift behind the inner face and knock them out.I use a slightly shaped drift.Finished off the front subframe. Of to the blasters next week.
Posted 02 January 2021 - 06:51 PM
Classic car workshop
Latest vid
Posted 02 January 2021 - 07:46 PM
The Hammer and Punch is a good simple method, just be careful though, that you don't bruise or score the machined tunnels for the bearings. I'd suggest a soft dolly (like Brass) rather than a steel punch.
I have some Sykes Internal collets that I use for this job. The one I use here also fit the rear trailing arm bush and bearing, as well as the Idler Gear Bearings.
