Show Me Your Battery Box
11 replies to this topic
#1 m445
m445
  • Just Joined
  • 32 posts
Posted 04 January 2021 - 06:13 AM
I need to repair my battery box due to rust.  I think the washer bottle was leaking fluid and caused the problems.
I want to consider changing the battery and better tie down.  I currently use group 26 battery which is 8.5" x 7" x 7.5"   It is one of the smallest batteries available in the US.  It fills the box and is difficult to get a good tie down to hold in place.
Show me how you have mounted your battery...
Mark in Michigan
Edited by m445, 04 January 2021 - 04:28 PM.
#2 Tones61
Tones61
  • 434 posts
Posted 04 January 2021 - 07:29 PM
#3 imack
imack
  • 2,207 posts
Posted 04 January 2021 - 07:54 PM
Powerlite and their bracket
#4 PACINO
PACINO
  • 764 posts
Posted 04 January 2021 - 10:57 PM
Amazing battery. So small .. I don't know if it would be enough to turn my engine with the cold it is doing in the morning.
If the question is not much, what liquid does that tube have?
Luis
#5 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 05 January 2021 - 02:45 AM
That’s a fuel line connected to the RH side tank.
#6 PACINO
PACINO
  • 764 posts
Posted 05 January 2021 - 03:20 AM
thanks Timmy! And wouldn't it be safer to carry it from the bottom like all the tanks on the left side, so as not to be so close to the battery in case of leakage inside the boot?
Regards
#7 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 05 January 2021 - 04:31 AM
That’s how the factory always linked the tanks together. The right side has a long metal pipe that goes across the boot, joins the LH tank and then down through the floor. There is also a battery cover and boot board that can go on top of the battery to prevent them touching.
Probably not 100% ideal, but that’s how we all do it
#8 PACINO
PACINO
  • 764 posts
Posted 05 January 2021 - 04:23 PM
cheers Timmy!
#9 m445
m445
  • Just Joined
  • 32 posts
Posted 06 January 2021 - 11:43 PM
Here is a picture with what I came up with.  I found the metal bar in my boxes of Mini bits.  I found the eye-bolts at the hardware store.
I still need to get a new battery with reversed posts (Group 26R).  This would put ground post closer to the boot lid.
I will shorten the bolts.
XkGTnBS.jpg?1
Edited by m445, 06 January 2021 - 11:44 PM.
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 07 January 2021 - 09:05 AM
That looks pretty much like the right (standard) way to do it.
Normally one bolt is an eye, the other is a hook.  You can also fit small hooks for the strap to secure the cardboard cover with.
http://www.minispare...s.aspx?2~20~203
Edited by GraemeC, 07 January 2021 - 09:06 AM.
#11 PACINO
PACINO
  • 764 posts
Posted 07 January 2021 - 08:32 PM
My battery fits so tightly into the hole that it doesn't need any support. Nothing moves.
#12 toromod
toromod
  • 43 posts
Posted 10 January 2021 - 05:46 PM
On my 68 Elf restoration I've removed the battery box completely, with modern smaller batteries my intention is to locate it in the wing behind the wheel arch - anyone else gone down this route? My thinking is by removing the battery box I will have a smoother underside less susceptible to stone chips etc leading to rust?
