Cold Oil Change
8 replies to this topic
#1 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 11 January 2021 - 09:39 AM
Car's been sat for a at least a month in my warmish garage. It needs an oil change but other than take the car out just to warm the oil for a change, I was going to do it cold, as I'd imagine all the oil thats going to fall to the bottom of the sump would have done so by now.
I usually do it warm but thought I'd ask. Also, I have ordered and received a K&N filter (one with the nut on the bottom) , it looks longer than the usual ones I get, assume it will be ok?
#2 Chris1275gt
Chris1275gt
  • 966 posts
Posted 11 January 2021 - 09:59 AM
I would imagine the crud would fall to the bottom when cold and warming and agitating it mixes it back up but draining it cold leaves the crud still in the bottom thus contaminating the new oil very quickly.
#3 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 11 January 2021 - 10:16 AM
I would drain it cold.... prob leave it drip overngiht... then put a cheap oil in.. fire it up warm it through, then drain it again once hot.. then put decent oil in...
#4 sonscar
sonscar
  • 3,048 posts
Posted 11 January 2021 - 11:29 AM
I would leave it as is until you start to drive it again and then change it but that is just my thoughts,Steve..
#5 Spider
  • 15,146 posts
Posted 11 January 2021 - 07:20 PM
I have just about always done mine cold. I just leave them drain a good couple of hours.
#6 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 11 January 2021 - 08:08 PM
I usually jack up the passenger side (RHD car) and let it drain cold, remember to clean the magnet on the end of the sump plug.
#7 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 11 January 2021 - 10:32 PM
Thanks all, and yes I will leave it dripping for a day or so. Good shout on jacking up the left hand side.
#8 croc7
croc7
  • 817 posts
Posted 12 January 2021 - 12:07 AM
I change the oil twice a year, about every 2500 miles, but always when its hot.  I enjoy the feeling of hot oil on my fingers when I pull the drain plug. ;D
#9 T.Harper
T.Harper
  • 714 posts
Posted 12 January 2021 - 01:19 AM
It won't matter in grand scheme of things.
