Correct Size Reamer For Valve Guides?
5 replies to this topic
#1 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 13 January 2021 - 07:20 PM
Searched quite a few times for this and see there are many debates over reaming honing and correct manner to do this job but don't seem able to find any info on the correct size reamer to use? Anyone advise?? Measured the old valve stem at 7.07mm --- 9/32 imperial would be the closest. But is that correct???
Rob
#2 Spider
  • 15,873 posts
Posted 13 January 2021 - 07:40 PM
I use a 9/32" reamer.
Honing is better than reaming, but for just about anything one would be doing with an A Series Engine, Reaming them is fine.
#3 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 13 January 2021 - 07:56 PM
Thanks for the info. I'm sure with a steady hand and a good reamer it should be fine. Reamer now ordered
#4 weef
weef
  • 559 posts
Posted 13 January 2021 - 11:07 PM
Be careful in your use of hand reamers. Reamers are designed to give a smooth true bore and typically it is only 1 or 2 thou they are designed to remove. Removal of more excess can lead to chattering and leave a wavy finish. The reamer rotation  should not be reversed and it is best to pass the reamer right through the bore and out the bottom, the reduced shank allowing this. Reamers do not self feed so keep a steady pressure, use a good cutting oil and go slowly.
#5 Cooperman
  • 23,569 posts
Posted 14 January 2021 - 11:59 AM
It is 9/32".
#6 Spider
  • 15,873 posts
Posted 14 January 2021 - 07:38 PM
Yes, I agree that Reamers are only for a few thou of material removal and in these sizes, those numbers would be typical. I'd also say if they need more than that, get better guides to start with, however, a 9/32" Drill Bit can be run through first, then Reamed. General Jobbing Drill Bits are never on size but always under.
